i have just changed to splitfire coils, and it is still recommended to keep the plug gap to 0.7 or 0.8mm. On the street it ran fine at larger gaps (i tried up to 1mm) but on the dyno it missed badly up top of the rev range.
as a point of interest, with plug gaps at 0.7mm, i gained roughly 3rwkw on the same dyno in the same conditions since changing the coils to splitfire, nothing else changed. Its probably insignificant, as i didnt do numerous runs and take an average, but its nice to see :(
oh, to answer your question, i would recommend it. Im only running 17psi, and the stock coils would give me a few misses every now and then, but with the new ones i havent seen a miss yet. It did also feel like it ran stronger after i changed the coils. May be Placebo effect tho!
Also if yours is an early series 1 33, the coils will be getting pretty old now.
Yeah, mine missed like crazy once I got past 15 psi, but I found all the coils were cracked.
Splitfires are a good upgrade, and I saw an improvment of around 5 - 8 kws or so, and the power feels a lot more solid (and I can actually floor it now....)
you can get them for ~$700 thru greenline or nengun or the like. Or if you want them ASAP Horsepower in a box should have them on the shelf and get to you in a couple days, but for around $900 maybe a bit more -not sure, check the website. High octane racing in NSW should have them also.
pretty sure price is same for series 1 or 2.
as far as i know, the splitfire series 1 and 2 coils are exactly the same coils, just the plug is slightly different, so its possible you could just use the correct loom/plugs with either coils on s1 or s2. correct me if im wrong.
guys,
is it worthwhile to upgrade ignition coils to spitfire when running about 18psi or r33 gtst? any feed back would be appreciated!
not really.
My car is fine and im over the 300rwkw for the time being.
I have no issues at all.
MY suggestion, put it all together and then see if you have any problems.
THEN spend the extra $$$ on getting them. That way your not spending money if you dont neccasairly have to
And some food for thought...
Whether the splitfires are actually better... who knows.
Remember your replacing 10year old packs with brand new ones, so of course they are going to work better
Thanks mate, i will run with the stock coils first then, if they work, i dont have to get the spitfire! :P
not really.
im of the belief that if money can be better spent elsewhere, then it should be... if not save that money incase something else breaks.
I dont mind talking from what ive found out of my own car which ive spent a lot of time/money on... some i wasted. And i'd hate to see others do the same
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
