I got some pics just got to get my girlfriend to load them(she good at Computer stuff) they are the same as a Skyline in the curretn High Pefromance Imports 6 coils mounted on the rear fire wall. mine are fitted differently.
shit, it's a series one i just found out. are the series two coils much better in any respect? thinking of going wasted spark with some falcon coils or something and remote-mounting on the firewall with leads. seems easier and it appears some people have issues with the 25 coils while others do not.
Mate if you can point me in the direction of an auto spark who can do this job in sydney then Ill do it, but i cant find anyone with the know how..
Try and buy the coil harness off a Series 1 RB25 car from these forums and get an ignitor module to from the Series 1 (obviously).
Im not sure if the Series 1 loom will plug straight into the socket when you unplug the Series 2 coil loom. (If it does it should be a straight swap)
At worst, the mechanic would have to either fit the correct socket or just wire the coil loom straight to the engine loom.
All the pinouts on the ecu's are the same, the ignitor module just has the transistor in that instead of being intergrated into the coils.
If you got the loom and ignitor any auto electrician should be able to do it.
If you go look at the back of the head you will see the coil loom plugs straight into the main harness, and you will get what i mean.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
