Just got a phone call from them today (to chase me up for a few piece of paper) and they've mentioned a few things what they will do in the future.
1) No more undertakings will be issued "eventually" meaning any cars that got in and haven't got the work done properly will need to be destroyed or exported.
2) Cars that have already arrived and cleared out will have random inspection done to see if the work is done as it's suppose to be. How that's gonna work, I don't know but if a Govt Dept tries to do something, I am sure they will have the time and resources to locate these cars.
Not meant to scare anyone but I thought just a courtesy to let you all know :cooldance:
https://www.sau.com.au/forums/topic/73262-deh-getting-tough/
I spoke to them as well and if people were not using forged De Gas Certificates or not De Gassing them every thing would of been fine,
They are smart some of these importers as they Scan a De Gas and use the same document over and over, when the crease is on the same spot over and over it is obvious what they are up to.
We had somebody scanning the last page and printing off various 15 year sign off's over here in WA, do some if these people think it is in place just for the hell of it.
When is the car supposed to have been degassed? Is that stuff submitted when the import approval is done? I bought a car in japan which already had the import approval done; so i dont have the paperwork for it. Hope it was done properly!!!
'exported/destroyed' is a bit scary!
Well if Customs won't release the car then what can you do? Export or destroy or, whichever cost less I suppose. I know a guy personally that forged a couple of de-gas and got away with it, I suppose if DEH is cracking down on this and demands to inspect his cars, he'll probably flip with a huge fine and for defrauding the Commonwealth with the fake cert's.
Then I asked them what if they don't like the certificate being provided? It has happened once to me already and they couldn't answer. Now I can tell you it's gonna become a bit of a lottery.
Well, here's to hoping it was done properly!
You should be eligible for an exemption from the DEH. You are entitled to one exemption between now and 31 Dec 05. Just photocopy your D/L and forward it to the customs guys handling your car when it arrives. You'll also need a letter stating your name, the VIN and that the vehicle is a one-off import for personal use (I think that's all you need to say?).
Beam over a PM if you want a hand with it and I'll send you a copy of mine. Don't let the customs agent charge you for it though. Seaway will do it for free (as it doesn't cost them anything), yet CGL in Sydney will charge you $150 to forward (read: fax) the letter you've just faxed to CGL. Apparently it's for their time/labour expenses incurred. Don't get sucked in. Choose a different agent as they won't budge on the fee.
Cheers!
Mark
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
