i just got a new map sensor and harness for my power fc because the old of broke (long story)
any ways i got a new map sensor and harness for it but the plug does fit into the power fc
just need to know is there any way of geting it to fit? like cuting the wires and changeing the plug?
if so where can i get the plug and how do i know which wires go where
because it only has 3 wires in the plug RED BLACK GREEN
IF ANY ONE OUT THERE HAS A POWER FC PRO USEING A MAP SENSOR I NEED UR HELP
or can i just buy another harness if so where from? Ill buy another map snesor if i have to as well !!!
https://www.sau.com.au/forums/topic/73268-apexi-power-fc-pro-help/
Sorry mate but I've got a Pro and it's AFM only, The only bit extra is a Launch control and Spark cut instead of fuel cut for the limiter
Taken from various websites -
APEXi Power FC D-Jetro
The D-Jetro Power FC units carry the same functions as the regular Power FC units but do not require the use of the factory standard air flow meter and use a mass air pressure sensor. Apart from the unit itself, use of the D-Jetro units requires addtional parts that vary depending on the model.
Power FC Pro Spec.CPU (for DRAG)
Only available for some car models, the Power FC Pro Spec.CPU has been designed for drag racing use. These units have two additional functions over the regular units:
Ignition cut used for rpm limiter - Regular Power FCs cut fuel feed when the preset revolution limit is reached. At high rpm, there is the possibility of knocking when the fuel is cut in high powered cars. The Power FC Pro Spec.CPUs cut ignition at the rpm limit to prevent the knocking that could potentially destroy the engine.
0km/h rpm limiter setting - Allows for the setting for an initial rpm limiter that is active whilst the car is not in motion. This allows for mainting a rpm level for consistent launches.
I've never found any info about Pro ECU's being MAP capable when I was buying mine.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
