Hi,
I currently have an R32 GTST with Trust Front mount, brass button clutch, blitz master access ecu, 3 inch from cat back, pod filter and cold air induction, bleed valve at 12psi... This gave me 144rwkw...
I was thinkin a 3in front and dump pipe ? what is the difference with having the screamer pipe ?
Thanks for the feedback.
https://www.sau.com.au/forums/topic/73283-next-mod/
