Dear RB26 specilest
My mechanic is asking few questions like
1. Can the head Bolts be reused ?
2. Can the Con Rod bolts be reused ? both are in good condition though.
3. How do you start tightening the head bolts? he means do you start from the center bolts then back to fwd or what is the best way, coz he works with ferraries and its his first time to work with the RB26 enigine.
4. Head bolts torque
5. Main bearings torque
6. Con Rod bearings
7. Cam shaft caps
8. Flywheel torque
Best Regards
Adel
https://www.sau.com.au/forums/topic/73300-rb26-engine-rebuild-specilest/
Tell your Mech to download the GTR manual :/ Tells you all the torque settings..
I normally reuse the head bolts and rod bolts. Maybe after a few rebuilds I would replace them, but never had any fail or cause any problems being reused...
Saying that, if you have the money to throw around, why not get new ones.
Can't believe you would use a Ferrari machanic, unless you have a Ferrari of course.
Why not use a machanic or engine builder that specialise in RB26...... just like the one you are working on. Maybe then you won't have to tell him his job and by the way, how to build an RB26
Re using most bolts is ok in basic motors but rod bolts are best changed every time and as even ARP bolts cost under $100 why wouldnt you?
I'm in total agreement, dont take the risk, they are the most highly stressed bolt in an engine. We replace them even in standard reconditioned engines.
