I have my Nissan Datascan tool for sale. $200 firm plus shipping. I have already used the tool to suss out all the problems with my car and now have no need for it. Used it probably only once or twice and is in excellent condition. The installation of the tool is very easy to install as it is a plug and play device which only needs to be plugged into the consult port of the car near the fuse box.
It is an excellent tool for finding problems with suspect failure in components such as Air con compressors, fuel pumps, O2 sensors, thermo fans, Leaning/rich fuel ratios and much much more.
The list of features this tool includes is:
rpm
speed (km/h and mph)
afm voltage
injector pulse width
injector duty cycle
coolant temp
ignition timing
tps voltage
absolute tps position (%age)
EGT voltage (if supported by ecu)
o2 sensor voltage
AAC position (%age)
battery voltage
Lean/Rich Indicator
Flags (On/off indicators): Closed TPS, A/C Relay, A/C Compressor, Fuel pump, start switch, VTC solenoid, thermo fans, and a few others.
More information can be found at:
http://members.optusnet.com.au/impakt01/nds/
https://www.sau.com.au/forums/topic/73302-fs-datascan-tool/
Nope it will only work on Nissans with a consult port which is on the factory ecu's and will work with chipped ecu's and systems with piggyback computers added on as well. I'm also willing to swap for a SAFC 2 with a cash adjustment obvioulsy or for a decent quality boost gauge.
https://www.sau.com.au/forums/topic/73302-fs-datascan-tool/#findComment-1348052
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
