I'll start by saying I know sfa about car audio so please excuse me if i ask stupid questions.
I have the following:
- jvc mp3 h/u
- mb quart splits
- signat 2 channel amp (2x60watt rms)
- pioneer 2 ways for rear fill (run off h/u)
- 10" mtx sub (will run 100 - 200 watts rms)
I need another amp to run my sub, my options are:
- buy another 2 channel and run two amps
- sell my current amp and buy a 4 channel
Will running two amps drain my battery of power so I won't be able to listen to my system for very long with the engine off? Will I need to upgrade the alternator or anything else?
Thanks for you help! :P
Cheers,
Greg
https://www.sau.com.au/forums/topic/7331-your-advice-wanted-please/
Running another amp = more power = more current drain. So in short, yes.
Depending on how good your charging system is you shouldn't need to upgrade your alternator. You might also want to consider investing in a capacitor - not essential, but will help "smooth" the current flow to the amps.
Why not purchase a 4 channel to run the speakers & bridge the sub of the 2 channel? By running fronts off an amp and rears off the head unit you will probably find that the rears won't have enough volume.
  • 3 weeks later...
to starr with...amps are designed to run when the car is running...ie. 14.something volts, not 12! so running it when the car is turned off isnt that good. but ive found if the amps arnt staining for power (not enough power for the speakers) it doesnt do much harm (well, noticably)
if you are only going to be running a set of splits and only 1 sub, i wouldnt worry about a capacitor, just upgrade your battery perhaps.
amp wise, a 4 channel amp would do the trick...2 for the fronts and bridge the other 2 for the sub. alternativly, you could get another 2 channel amp, depending on where you are going to mount them and how much room you want left. remember, amps are generally designed to get rid of the heat when they are sitting normally...so if you mount it upsidedown and its being put to its full potential, you might have an over heating problem and then bye bye amp!
hope this helps, hope i didnt sipn too much crap!
  • 3 weeks later...
thanks all for your replies :D
i've decided i don't want to spend money on another amp just yet...so here are my options:
a) Use the amp to run my splits, and run no sub for the moment
B) Use the amp to run my sub and run splits from the head unit
I'm leaning towards (a) because my splits were pretty expensive and are quite good quality so it would be a waste not running them off an amp.
what do you think?
Yup, subbies require more power to generate a decent volume.
Hence why most subbies are around 1000w and you will not find much above 300w for other speakers. Really for a sub, an amp is essential whereas for splits its not.
I hooked up my splits to the amp but it lacked bass... so then i hooked up the sub to the amp and ran the splits from the head unit. It sounds sweet :D
I might get a cheap 2 channel amp to run my splits though because the sound is so much clearer with an amp. Anyone know of any amps for sale?
Thanks for your help all
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
