  • Replies 49
Hey Cristian sounds like you got a nice ride where abouts you located north or south side?
I actually live just out side of Canberra. I live in Royalla, anf for the guys that are not sure where that is, it is 10 mins down the highway, from calwell (so southside)
https://www.sau.com.au/forums/topic/73338-hello/page/2/#findComment-1348645
It may be a half cast buddy, but its still quicker than yours!
If I wanted a 33 I would have bought one, I did up a 31 cos its uncommon to so (not like 33GTSTs) :)
Incase you havent noticed their is plenty of R31s around. They are pretty common.
https://www.sau.com.au/forums/topic/73338-hello/page/2/#findComment-1370031
    • Yeah been doing it in an x shape. Do you reckon it's worth putting guide coat early where the filler isn't sanded down completely smooth? Reason I ask is because as I'm sanding it one part might be level which I don't need to sand anymore but the other part might be high so I can just focus on that instead of sanding across the whole repair area. I wonder if the putty is too thin, though the area is almost completely smooth before I do it as I've already put filler prior.
    • Just 2, and inline. One switch temp related other switch driver controlled.   I'm nearly in my head back to Arduino land for it...
    • Complex conex, sand in X shape. And don't go hardcore. I find putting on filler to be the art here to help.
    • Hey y'all, I have a completely stock 1991 R32 GTR, yesterday I took my car out and went for about a thirty minute drive. It was fine on the way there but when returning home I think the car might have gone into a limp mode. I was cruising in 5th gear around 130km/h, the hicas light came on and there was a significant loss of power. About a minute later I hear a thump, the car starts driving normal again and is fine the rest of the drive back. This is the second time its happened, same as now it was fine on the trip there. On the way back it had the hicas light on but that time I would feel the power going in and out before hearing the same thump and it being fine.  I have no idea idea what causing this, but if anyone has any ideas it would be great as a start chasing the cause of this. Also I can provide more details if needed. Thank you
    • When sanding across a convex panel, you need to sand, as much as possible, at right angles to the curve. If the panel is compound convex curved (ie curved in both directions) then you are SOL and have to use "craftsmanship" to get it right.
