Hey all,
Do you want to be able to estimate (for any car):
1) 60ft time
2) 200ft time
3) 1/4 mile time
4) 1/4 mile speed
5) Wheel spin / traction graphs
6) Most efficient shift points for best ET or best terminal speed.
7) Accleleration graphs
8) Distasnce v time
9) Gradient charts
10) and see what effect varying hundreds of vehicle parameters has on all the above.
and more...
Then take a look at the Excel dyno (excell file) that can be downloaded in the following location.
http://autos.groups.yahoo.com/group/exceldyno/
It is a really cool excell file based on visual basic macros that allows you to enter data about a car and accuratly estimate heaps of performance parameters. Inputs include, engine dyno data, car parameters (CD, weight..etc), tyre setup and more. It allows you to set shift points or have it calculate the most efficient points.
All credit for its creation goes to Wez, a mate form work. He is a mechanical engineer and has had a fair bit of experence playing around with cars - he also seems to have a lot of spare time :P He has set up a Yahoo group for all things Excel dyno, if your interested take a look.
It has been tested with a number of different cars and it has proven to return supprisingly accurate results.
Of most intrest to people on this forum would be the R32 GTR data that is already entered in the program - this data was based on another workmates car and gives very accurate results when tested at the drags. Just enter your dyno chart and car details and you can start dropping those 1/4 times.
You can always add any car that is not already in the program as long as you know all the parameters.
Here is a list of car/bike data that is already entered in the database:
93 MR2 Turbo
95 200SX SE-R
Ford Falcon AUIII
Ford Telstar 92,95
MX6 - Gen II V6
Subaru WRX
VW Baja
VW drag manx
R32 GTR
Suzuki DL650
Suzuki Hayabusa
It is all free but if you want to give Wez cash I'm sure he will not refuse:) just email him on the address at the website above.
Ray Hall also has a similar thing.....
http://www.turbofast.com.au/Drag.html
Except that is more a rule of thumb than any sort of remotely accurate calculation.
If people want to find car specs and send them to me then I will post a new version of the sheet with the new cars up on the net.
The cars that are in there are just a few that I had some good data for so entered to check the accuracy of everything. Finding the aero data is the hardest.
Hey Wez, did not take you long to find the thread!
Like Wez said, his program is in another ballpark.
I thought I'd post up the calculated best shift points for a R32 GTR, that should get things going:
For best km/h: (this gives 11.155 @ 202.7km/h)
RPM GEAR km/h
4000 stall speed 36
8500 first 77
8200 second 124.2
8010 third 179
8020 fourth 234
8500 fifth 330
For best ET: (this gives 11.144 @ 201.8 km/h)
RPM GEAR km/h
4000 stall speed 36
8500 (redline) first 77
8500 (redline) second 128.8
8500 (redline) third 190
8500 (redline) fourth 248
8500 (redline) fifth 330
Here is a bit of an explination of why the shift points are different when chasing high trap speeds or Low ET's (from the Excell dyno)
These shift points will give you the max terminal speed for the 1/4 mile. These points are essentially where the torque curves cross each other on the Traction chart. Note these points are not always exactly right as the wind slows the vehicle during gear shift making the best shift point estimation more difficult.
However, to achieve the best ET you generally need to change gears a little later. This is because shifting later means you are going faster for the during of the shift time. This means more distance will be covered. The optimum shift point is when the advantage of shifting later if offset by the loss of being too far past where the torque curves cross. These points are easily found by trial and error. Start with the best shift points for terminal speed and increase the shift rpm from there. For most engines the best ET will be achieved by revving to redline.
Well when the car had the 291HP dyno chart it ran the quarter and ran an 11.9. The Excel Dyno predicts that run perfectly.
With the extra 85 wheel hp it should easily push the car into the low 11's. I can't remember if he got a time slip before that engine spat the ceramic turbines through the engine.
I had a quick look - R32 GTR with 375RWHP running 11.1@125mph? i doubt it...
Does that mean you entered your car data? Is that what the excell sheet returned?
220rwkw (291rwhp) ran an 11.9? what mph? that must be a low dyno reading, what boost was he running?
Ferni,
That was my car. I'm pretty sure I have told you about it before.
When my car arrived from Japan it made 217 rwkw. That was on a dyno dynamics dyno (non shootout mode). I ran an 11.99 @ 115.4 mph at our drag strip here in Townsville.
I have been involved in the development of excel dyno and I can say that it is very accurate, as long as you give it accurate data. It's in a league of its own compared to most other programs out there.
I will write more later when I have more time...
Hey Gary,
Didn't know you had a 32 GTR last time I was up on site, prolly a good thing, I would have spent more time talking about cars than getting the full "QNI experence". I have to take a look next time I'm sent up there.
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
