expressions of interest, rb20, trust, microtech, new cooler and piping
ive decieded to sell everything as i want to go a rb26. everything is for sale if i get enough interest.
RB20DET, has 1 cracked piston, otherwise gc, no manifolds $500
TRUST TDO6 20G turbo kit, for RB20/25 Greddy high mount manifold, turbosmart 45mm gate, braided oil line, exhaust from turbo to cat in stainless, 3in all in pc, new seals in turbo, $3000
custom plenum, ready to bolt on, with throttle body, sensors, 440cc injectors $1000
microtech LT8, pc with rb20 loom $1000
RB20 gear box, crunches on down shift into second, only needs new syncro, $350
brand new X Racing bar and plate intercooler and stainless piping to suit current setup, all new. $1200
serious buyers only, and i dont care what u can buy the same parts for else where, do not reply if u dont want to buy or have any interest in these parts.
i can email pics,
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
