Al, I've got to agree with Troy, go to Wilko's they will supply, fit and align then with the new bushes, makes a difference to the handling too:D
Paul,
Can you tell me roughly how much are they and where is Wilko's.
And how much of a mamber discount do I get?
cheers
Al
I got mine done 2 mnths ago at Glenmount Automotive, polyurathane bushes also, cant remember exactly how much it cost as i had a few other items getting fixed but it was about $120 installed. Wont hurt to get a second price.. Ph- 9544 4000
']Al, i am in the same position as you, my bushes are fu*ked been like that for along time. i think ken told me it was about $200 each to replace
How can that be, when the front rotor cost that much, how can a piece of rubber be that much......Ken must do a wheel and suspension check for that price.
I seriously think something is wrong with that price. $200 is more realistic to replace all of the bushes on each side.
I know the upper arm bushes need to be done by a specialist. I looked in the manual and it's no big deal.....to do the bottom ones.
Well if that is the case this Skyline won't be seen north of the river......
:flamed:
:flamed:
:rofl: whoops it wasnt the bushes, i got price for (i feel really smart now :P) it was the castor rods hehehe closes enough :rofl:
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
