  • Replies 1.8k
Posted Images
VAPE you are a legend man!
finally someone put up a detailled view of it :ermm: ...
so it works fine and holds boost constant?
Cheers mate,
-JD
PS:
Your hose looks like its not fully secure.. actually it looks like its not even under the metal tie...
Edited by JD-33
finally someone put up a detailled view of it :yes: ...
Cheers mate,
-JD
PS:
Thanks JD.
Holy crap, i didnt realise that hose was not secured haha. maybe that is why my hicas light is on lol.
I got so confused about eveyone's directions on that controller, even the picture that was sent with the unit in the mail didnt make sense to me. People seems to put it in different ways. So I tried the manual version, and nothing happened, less boost and nothing when i turned the screw. then did it another way and it was overboosting like mad, so i had to unscrew coz i crapped myself thinking it would break somehting lol.
Anyway, thanks for pointing that out!
Vape
Thanks JD.
Vape
That "unsecured hose" is just a protective sleeve for your power steering line. What you have is normal and is nothing to worry about.
if any one can help my freind want's to know if you need two of these to run a 300zxtt.
If so how will it be needed to be tee'd.
the reason i ask is because he is so impressed with my jrdsports mbc they have a special of bulk buy and he want's to get some boost running through his mildly worked 300
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...AMESE%3AIT&rd=1
hey guys can anyone help me out? bought one of these, installed it on my 33, if i run anymore than 8psi boost it splutter, misses and carrys on between 4000rmp n 6000 rpm. i got some free dyno time (only kw reading, couldnt ajust ecu) the other day and had a play n the best rwkw figure i could get was only running 7.8psi boost! do i need to get on a dyno that can adjust my computer (timing, air fuel? also why do u thionk my car can only run low boost wen i hear of other people on here being able to run 10-11-12psi on the same car and not have any worries!
thanks 4 the help!
cheers
brett
Mark,
Transaction made via internet banking. Reference number quoted...
Cheers....
Did he reply back to you, i have been trying to get a response from him since last week, through here and through eBay. I would like to purchase it through here but i do need one soon.
I dont care i would order one through ebay if i really had to but if he cant reply to my messages, how is he gonna send the item if i hit "Buy It Now".
I would like a reply just for acknowledgement at least.
thanks 4 the help!
cheers
brett
try gapping you plugs to .7 or .6 and see if the miss disappears.
I suspect the miss is coil pack related from the symptoms you have described.
Hey guys just put this on my wrx with 181@ wheels on 16 psi, my old controller shit itself couldnt create no more boost. put this on and it totaly kicked its ass, hits 17psi by 3200 in 4th gear and holds it perfect there. im so glad i got this instead of something else... Took me about 1 minute to put it on and about 30 secs to adjust and i was soo happy with this product best 42 dollars i ever spent.
just got mine ine the mail! cheers buddy ill shove it in the weekend and see how it goes. took aa bit over a week to arrive but it says next day delivery lol. Dont really care as long as it gets here looks pretty good. thanks a lot to vape looks easier now
man just installed it, couldnt wait :) warmed up the car then stopped shoved it in on the side of a 70 road then checked what boost...it was a little bit "infinite" for my liking i had wound it out as far as possible and was expecting less than stock. turns out i used the wrong hose and after i figured it out (no net on the roads edge) it pulled to the mark between +7 and 0 on my stock r33 boost gauge.. in 2nd at like 2000rpm! kicks in hard used to sorta build over a second now its just bang. im not one to go over 3-4k rpm so im very happy with the result.
on r33 gtst, it is the two LARGEST DIAMETER hoses that are connected to the controller, everything else you can block or remove. Stock solenoid is taken out of the loop by removing the t piece and its small hose and plugging the other hose with a screw or similar. use the existing clips to hold the hoses to the controller and shazam u pull like a v8. a big v8.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
