Just a quick question...
I have this installed to my external gate and although not really a problem, i would just like to understand a bit more as to whats going on.....
I have the boost signal coming from the manifold of my RB20. I have just increased the boost from 9psi and now it runs 11psi in first, climbs to about 13psi in second and gets to 16psi in third and i have changed to overdrive and it climbs to 19psi... I have a manual shifted auto with a 5000rpm stall. It is not a problem at the moment as my afr's are coping but i would like consistent boost in the near future :rofl:
Cheers
Steve
  • Replies 1.8k
Posted Images
Anyone here have tried both "ball n spring" vs jaycar IEBC.
my gfb sux, wanna try jaycar soon but after reading this thread i feel like giving it a go 1st.
anyone here have experienced both controllers?
I have, first bought the turbotech one, it didn't hold boost with my turbo, tried everything to make it work but I have an aftermarket cheap t3\t4 I bought on ebay which didn't like any cheap boost controllers, so I bought the jaycar ebc, does the job for me, but I had to tune it completely different to the examples given, because my turbo has issues. Still after playing around with ebc it was much better for my application. Would recommend jaycar to anyone who can solder and follow instructions.
FOR SALE- TURBOTECH BOOST CONTROLLER $35 as new delivered.
- Turbo XS Bleed valve $35
I just got my hands on a turbotech, I fitted it up and tried it out yesterday.....I've got to say that my GFB atomic bleeder did a better job of holding boost between gears. With the turbotech, boost dropped down as much as 4psi between 1st to 2nd. Keep in mind that this is with an auto with a manual shift kit, so I might have a different result those with a clutch.
To the turbotech's credit though, it does not spike at all, where as the GFB does slightly (1psi on ramp up).
Response time between the 2, didnt notice much....perhaps the turbotech was slightly more responsive, but this was probably the placebo effect after hearing so much good stuff about it :angry:
don rb20's make max power at 6400rpm,
that may explain the spiking at around 6700rpm.
But its not spiking.. Boost is dropping 1psi.
You may want to bung a nipple in to the ic pipe that attaches to the cross over pipe and block off the one used on the turbo. Similiar to how the R33's are setup. This will prevent boost drop with bleeders. No guarantees but its a step in the right direction.
i havent been back tracking but your saying you dont know why yours is spiking, dezz?
yep
whats more odd than the spike itself, is the fact that it spikes at 4500rpm (when on full load)..
4500rpm is when the stock R33 solenoid kicks in with its 2 stage boost from factory, when boost goes from 5 to 7....
mine is pretty much going from whatever my boost is set at, to +2 at 4500rpm....the stock solenoid is completely disconnected.
it was doing it on the stock computer, but now has a pfc and is doing the same thing, so ECU can be ruled out...
its gotta be something turbo/wastegate/dump related.
HAYY i was going to post the same results. I had my car on the dyno, and the controller was all aover the place. I took it apart and realised the spring was the wrong way around, fixed that, and it a littel, marginaly better. basicaly the controller set to 10 pis, will spike at 4500 all the way to 12 or 13 and then bleed off down to 10 or 9 after 5500rpm.
This sux for me cos as it spikes the computer goes to R&R and creates a flat spot, then all good.
IF i don't use WOT, then the controller is ok. But it seams slugish, mine doesn't come onto full boost till 4000-4500 rpm.
Has anyone found a solution to the problem or something. I am thinking i might switch to the JAYCAR boost controller or the HYBRID full electronic boost controller.
AVC-R are tooo expensice and teh jaycar kit does the same job, just needs to be tuned on the dyno to get propper results.
THOSE with the JAYCAR kit, how did you find tuning it, can it be done on the road?
You'll find the same goes for the AVCR. To get nice results without spiking, maximum boost response and holding boost in each gear you really need to set it up on the dyno. This is also why some claim the avcr is crap; because it hasn't been setup correctly. The blitz sbc-id is the next step down from the avcr, when I say next step down I mean features. It lacks an important little feature that allows the selection of different gain levels for different gears, this affects that gears boost response. I found the lower gears to feel a little sluggish up on to boost IF the controller learnt boost in a high gear. Have the controller learn boost in a lower gear and it would tend to spike in the high gears for example up a hill.
does anyone know how well these would work on a prety stock 32 gtst?
would it be worth it?
what qould be safe boost level with stock turbo?
whats the legality in sa?
Edited by minger
i got a rb20 running a rb25 series2 turbo.
i basically run 14 psi
boost spikes for half a second to 15psi, then sits on 14psi and goes down real slow to 13psi by the time it hits redline.
i think it works well on my car.
minger
on a r32 with exhaust and air filter, you can run up to 14 psi as long as your air/fuel ratios are good
if you dont know, run 10psi to be safe!
and u will notice a difference in power!
there's a flat coiled side of the spring, and a cut uneven side.
i assume the flat side sits against the ball bearing. Is that what you found?
i'd be putting it down to the cams changing over, and more air coming out of the motor at high rpm and the wastegate can't handle the extra air.
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
