  • Replies 1.8k
Posted Images
2 days is nothing to worry about.
Chances are he will simply send it out.
Also with regards to the boost controller..
I found the adjustment to be a little bodgy as the top of the spring would often jam in to thread; I bent the top of the spring in slightly and now its extremely smooth and so much easier to adjust.
yeah i pulled mine apart and had a good look before using it. the cut end of the spring was ok in my case, but i can see how it might be a bit dodgy. i have adjusted it once and left it like that (fluked the correct setting first go).
here's a tip. if you want to install it at the least(stock) boost, tighten the nut just enough so when you blow thru the bottom nipple with your mouth, you can just get the air to come out the side nipple with quite a bit of blowing effort.
Edited by Munkyb0y
crap man i lost the ball when it fell apart trying to lower boost too much, it is gone, ive been trying to find a bearing or something of similar size with no luck,
i remember when i first read this thread and someone lost the ball and i was like ha what a dumbass but now i see lol
anyone have any luck replacing it?
Anyone have any ideas on what i can do to make it hold boost a little better ???
Hey all as per my post i think like 20 pages ago i managed to get mine working and it has been going strong alot better than my previous turbosmart pos. Anyways i have upped the boost to around what i thought was 11psi. After doing some high load runs i found that it was getting up to a max of 11.6psi at 4500rpm and then worked its way down gradually till 6800rpm when it was down to about 9.8psi. I have checked the lines and they are as straight and short as i can make them. Other than maybe trying to shield the BC from the engine bay heat do people have any other ideas on what i can do.
Summary is below
4500rpm - 11.6psi
5100rpm - 11.1psi
5700rpm - 10.7psi
6300rpm - 10.0psi
6900rpm - 9.8psi
PS i know it's a cheap boost controller and can't expect the world but 1.8psi is a fair drop.
maybe its got something to do with your acuator.
Mine seems to hold boost fine. Unless the spring loses it's tension over time....??
Thats just my uneducated guess.
Edited by KeyMakeR33
i set mine to 9.5 -10psi and when i come on boost hard the thing hits 11psi for a split second then sits on approx 9.5-10psi like i set it
anyone got a pic of the thing pulled apart? just want to see the size of the ball compared to the spring. need this guys i miss my boost, running on wastegate.
http://www.autospeed.com.au
Edited by Thunderbolt
if you cut the spring, you just have to screw it in further, best mod for this controller is to remove all restrictors in the lines if there are any and have more pressure acting on it which makes it a bit more accurate. i put the flat end of the spring to the ball, as it seemed like something you didnt want to foul the movement of, as opposed to the bolt that stays still anyway.
bearing i found worked by the way, and i have 12 more here lol. as long as it fits in it will block the end
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
