I found a good cheap boost controller for $22!!!
  • Replies 1.8k
So are you saying that the new design reduces lag after a gear change? I've been noticing lag on changes lately...and I dislike it a lot :)
It could probably be tuned out, but if the hole in the boost controller isn't helping, I might get the newer 1...
have you got the hole in yours?
as far as i know, the hole should actually reduce lag on gear changes.
i'm feeling the lag too, but mine has no hole. i might put one in it.
Hey guys i was mucking around with my controller and i took the screw out and the ball and screw came out.
When i put it back together, does the ball bearing go in first then the spring, then the screw? or other way around?
cheers
cheers
ball, spring then tap
so these are standing the test of time.. no one has had no big problems with them as they age?
i set mine, and left it. hasnt deviated or played up at all. pretty damn good for the price.
Edited by Munkyb0y
sorry i havent read all 64 pages before maybe the first 10 or so but didnt find the answer. so just a few quick q's if anyone can help
1 - are these still available ?
2 - are they a boost controller that gets rid of the original solenoid in the r33 so u can run whatever boost your car is capable of?? (sorry 1st turbo car so not 100% familiar with the system)
thanks
the r32 guys run more boost, but as far as i've always known, 12psi is the limit on the R33 turbo...anymore is pushing it further than you may want to....and not sure they make any power past 12psi anyway...where's paul when you need him
Just for some more feedback,
I have scince bought a new car and ordered another one of these, the new one does not have a hole. In the process of tuning the car I was monitoring the boost.
I am running a sliding performance RB25 hiflow turbo on an RB20 pushing 230rwkw. The boost controller was set to 17psi. The controller held boost so well it looked like a flat line. it was as good as the EBC that came on the car when I bought it. Infact I took off the EBC and sold it for $350 as the turbotech did the same job for $30 and could be hidden in the enginge bay and there is no solanoid or electronics to fail.
Gotta love it.
well i just bought one for my r this morning will see how it goes when it arrives
well i fitted mine this arvo and it works a treat set @ 1 bar i can feel the difference compared to my old grid ebc whick only worked intermittantly car is way more responsive now boost comes on a lot erlierand stays full boost til 7400 then drops down 0.1 bar
