  • Replies 1.8k
Posted Images
just make the hole where cubes said.
Mine has the pin hole directly opposite the nipple that feeds the wastegate actuator, so smack in the middle.
here's a pic
lol...as you can tell, i'm quite keen to see if this fixes the lag :)
It may not be the contoller that is causing the "lag". Lag between gears is normally because of long intercooler pipes. When you change gears the air gets released from the system, and has to travel all the way along the intake system again. This cannot happen instantly, so you may feel some lag. This is one of the reasons why the V-mount intercooler systems are so popular in Japan.
I've got a blitz LM front mount...pipes are shorter than all the hybrid/trust/hks etc kits....
Lag caused by a boost controller not releasing the pressure between the boostcontroller and actuator cannot be mistaken.
As you grab the next gear boost comes on really really slowly and smoothly. It sucks. :no:
Yes front mount systems add some lag to the setup but i feel that it is more throttle response rather than on gear changes at WOT that it effects. A simple test is just remove the boost controller and put a tee piece back in or a line straight from the ic piping to the actuator and you will see that the boost response is much better on changes-basically instantanious - hence the controller is causing the wastegate to stay open too long...
I brought one recently and it doesn't have the little hole in it. I don't get that lag everyone is talking about, I don't have an FMIC though with long piping. It does seem to drop of boost significantly (3psi or more) at high RPM though, but I assume this is something else, not the Turbotech MBC.
Anyway I've ordered the Apexi Boost controlle for the Power FC so I will give that a go.
that's pretty normal... 2nd of feb was a friday, so the money wouldn't have hit the account until about 6th or 7th . Gotta make it then, and then send it out, so probably not enough time to receive by today. Don't worry you'll probably get it mid-late next week some time. He's just a one-man-band.
well all is well, its sweet as to drive boost hits hard much harder than factory settup.
but the only downfall is that it looses boost up top. i have it set at 14 pound atm. and when it drops off up in the high revs it goes to 11-12 pound... so not too bad it still pulls.
definatly an improvement!!!!
next thing i will buy is an EBC but untill then im happy with this
even tho i had to drill the hole my self... grrr....
yes, drill the hole.
cuz if you dont it keeps your wastegate open when you change gears and it lags like a mo-fo.
so you need to drill the hole to let teh extra pressure in the line between the actuator and the BC out.
my 1.1mm hole works just fine, so id say anything around that size would be good :D
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
