  • Replies 1.8k
Posted Images
  Munkyb0y said:
dont quote me on this, but i think +7 on the stock boost gauge = ~14psi
700 mm of Hg @ 0°C (where in Australia would you find THAT?) = 13.53 psi.
Quote me.
Dan
  groper said:
they have steel wheels, otherwise standard :huh:
only GTR standard turbos that are steel exhaust wheels are, N1 or nismo turbos. the R32 R33 R34 are all ceramic exhaust wheels.. unless they are a N1 or A/M set. :D
i fitted one to the S14 today need a gauge for it.. so waiting till end of the week.
mark sent me mine in around 3 working days from payment.. quite quick.. :wacko:
maybe groper's referring to the fact that he either has one of the 'factory' steel wheel turbo's or he's had the ceramic ones replaced with steel wheels... possibly...
ok like the 100 other posts before. i purchased one of these boost controllers. i already have a gfb valve already set up on the car and was installed by the previous owner. could someone give me a quick run down of how to install the new boost controller in replace old the gbf, is it just a straight up swap.. disconnect the hoses from gfb then connect them to the turbo tech one?? or is there any change or extras i need to be concerned with. im installing it asap so any imediate help would be awesome!
thanks
jake
so anyone posting a DIY mod for retards or what ?
mine should get in soon so i can hit up 10psi. i dont know what it will look like or how it will work bt if its shithouse on a gear change i will want to change it.
Edited by gts-4 dreamer
Yeah man is that a question?
Look at the link in post 1449 on this page for a "DIY guide for Retards" ha ha
edit: grammer
Edited by KeyMakeR33
  gazza750 said:
i run mine without the hole and have no boost problems whatsoever with it .
it spikes a bit early in the rev range but after that its quite good
That looks like quite a bit of a spike though 16.5psi down to 12.5, did stock boost on your car hold a flatter manifold pressure?? looks like it fluctuates quite a bit.
hey guys,
i just installed this boost controller in the other day.
it seems pretty good now that i have drilled the whole but 1 thing i dont
understand is that i wind the nut all the way up (lowering boost) yet my
boost guage shows .7bar to .75bar BUT if i was to wind it down (up the boost) my guage will show .8 .9 1 depending on how high i set it, so in other words i cant get it to stock boost.
Shouldnt it be showing .5 because the boost
is all the way down???
would this be because the controller isnt installed right or boost guage not reading right.
MODS:
cat back exhaust
pod
atmo BOV
(apexi boost guage)
any1 come across this before???
cheers
Edited by RB32
