Hi guys im from the Uk and own a r33 gts t, ive been asking questions on other forums in the uk about this device, and have been advised on the following.....
is not advisable to allow the car to run the higher level of boost early in the rev range due to the ignition advance in the lower rpm range, removing the 2 stage boost control will allow the boost to run at .7bar from 2500 rpm and the ignition map will be too agressive to allow the engine to run without detonation.
Im not wishing to name names here but would just like to know what your opinion on this comment is.
Im not a mechanical wizard, and really just want to know the 2 sides of a coin so to speak.
Im just intriqued:)
What you say is true to a certain extent.
the r33 computer does provide more ignition advance lower down.
and you should NEVER increase the boost with a standard car without checking AFR's and ignition timing.
Having said that. i have never seen a probleb boosting a stock r33 to 10 psi.
  • Replies 1.8k
Posted Images
Well I installed mine today. Had upgraded from a GFB bleeder. I also checked the knock levels on the PFC while testing the performance, it may have even been knocking slightly less with this controller. It still hooks up nicely, having full boost earlier dosen't produce any traction problems on my car.
One issue I found with my car, is that the vacuum hose that I had (believe it's the hose that came with the GFB bleeder) didn't fit well over the nipples, but had some spare slightly larger vacuum hose (blue) and that fitted beautifully.
ps. My car is SR20 180sx for those that don't know.
I'm also from the UK and have been debating this device.
Surely if all you want to do is have 10 psi / 0.68 Bar at the lower rev range then just cut the wire advised here http://www.skylinesaustralia.com/forums/sh...ead.php?t=42895
12 psi = 0.82 bar and I am told this is unsafe for the turbo and will drasticaly reduce it's life and put strain on the engine and most definantly cause det, due to the reasons posted by my UK friend above.
If all this is true then surely this device is dangerous and a bit of a gamble.
If any can explain why it is ok then please tell me, I am only going on what I'm being told from the UK, pesonally I'd love to use the device but don't want to do so unless I'm confident the turo wont give way and I wont get det.
modding cars is allways a risk. running 12 psi is a calculated risk. from all the data gathered you have to make your own decision.
listen to others experience and follow it.
ofcorse you will use more fuel, shorten the life of a ceramic wheel turbo and so on if you don't tune your car properly.
But its like anything. I wouldnt run standard 92 octane petrol in my car and go boosting it everywhere because it is a risk.
but speaking from experience 12psi is "fairly" safe with a stock turbo. However, I have seen them die at standard boost. and i have also seen them running 17psi without failing.
the device is not dangerous, but yes like every aftermarket part you can buy for your car it is a bit of a gamble. but any device that increases boost presure is exactly the same.
as for the increased timing in the lower rev range promoting pinging at 12 psi with this controller, if you run premium fuel and standard base timing you should never have a problem.
in the end you have to make up your own mind...
it me it's not even an issue,
Thanks for your opinion.
What octane fuel can you get over there?
We have 95, 97, 98 From Shell Optimax and some very rare places have 99 at a supermarket which has just been released.
Hi Japtastic, we have 92 octane unleaded and most cars use that. then we have 95 octane called premium unleaded. and then we have shell optimax 98 octane and also bp ultimate 98 octane.
I have also seen 100 octane fuel but it was an independant service station. we use 98 octane in performance cars here.
Im just intriqued:)
That 2 stage boost controller is there mainly i think to stop wheel spin in the lower gears.
Hey dudes
Sorry for interrupting
Bought one of these off ebay yesterday and am going to get my mechanic to install it on the weekend.
Just a question and sorry if its been asked before, but would the stock boost gauge be OK for testing?
Just in case I bought a boost gauge off ebay too.
My car currently has stock boost.
Dang, havn't even owned my Skyline for a week yet and I'm already after more boost!
Haha Gengis I'd drive your car a little while longer before boosting things. Just like a month or two to see the general condition of the car and if theres anything that needs attention or fixing first.
Well to answer your question, you're probably best installed the boost gauge at the same time and use that to see what boost your running.
Standard boost gauge and standard oil pressure gauges are notoriously inaccurate, it would be stupid to try and rely on it to check boost while setting this device up, you'll simply end up with a broken skyline if you do.
Feedback time and I'm hoping this will be taken as constructive feedback as that is how it's meant. :)
Well, I installed this bleed valve in my HCR32 yesterday and went out on a road test to adjust it ( keeping in mind that I'm running a HKS GT25/35 and 1.2 bar of boost ) I spent about 40 minutes out on the open road trying to tune it but this valve doesn't seem to suit my requirements because I couldn't find a way to make it work.
With the bolt ( adjuster ) screwed almost all the way out it was making 0.6 bar at best and with minor increments ( screwing in 1/4 turn at a time ) it was making no difference until 1 & 1/4 turns inwards. At this stage the boost spiked to 1.5 bar, fluctuated violently and then settled at 1.2 bar.
I went as far as pulling the valve off and pulling it apart to ensure that all was OK and then went through the whole process again with much the same results ;)
I AM NOT saying this valve is bad but more stating that for higher boost applications, I found it to be unsuitable. If you're boosting a stocker, I'm confident that this valve would be good :)
In summary, if anyone would like to buy this one off me, let me know as I'll sell it for $20 plus postage. PM me if interested.
Sounds like you got a dud. ;)
Mine is actually very accurate with only the slightest adjustment varying boost.
I've had mine up to 15-16psi. Obviously I havent kept my foot in to it as she was leaning out in the top end due to small injectors.
If your running a aftermarket turbo and other mods i wouldnt be relying on this type of manual boost controller. I would invest in a good ebc.
Agreed ;) and I will buy an EBC soon, but for the money, it was worth a try :)
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
