  • Replies 1.8k
Posted Images
i bought one of these bad boys as well!
will find out in the next few weekends how it goes myself when i try it out...
also only took 1 week from when i bought to when i had it in my hand - recommended seller for sure
does the guy make them himself?
um tried it out tonight
holy shit all i can say is get one everyone these are the shit i have not seen another device work as well as this
first run was scary guage went over 20psi on the guage so dont know what boost but blew the intercooler hose off even with those big industrial clamps
we
hen i got it sorted it16psi boost came on slightly quicker but hit like a hammer and response is more defined now as well, but also when it hit 16 there was no spike nothing just sat at 16 and did not move up or down
i am extremley happy with this
everyone throw your old boost contollers away and get 1 of these
we
20psi?
did you adjust it wrong or something? it has to be fully open to start with remember...
Its to prevent the boost being held between the actuator and the bleeder.
When this happens even though the car isn't making boost there is still boost between the bleeder (ball and spring) and the actuator, this holds the actuator open and makes a very very sluggly boost up between gears.
yeah i know lol
for some reason we where trying to find what the nipple on the top of the externall gate did so i conected it to that
first runn did nothing second with a full turn nothing third time again full turn nothing so put the tap in line on the bottom nipple and forgot to wind it back out very silly on my behalf
just stocked how well the car ran at (over 20psi as my gauge only goes to 20) over 20psi
not ping nothing it loved it right in the meat of the turbo efficiency the car loved it but i got a bit scared so yeah
now at a hard and relaible 16psi i cant believe how well it holds boost
like a rock!!
ha ha
i am dying to put mine in too, but i'm going back to melb for the weekend... so i have to wait untill next weekend! :cheers:
grrrr
Ok so i just purchased myself one of these bad boys, hope to see it by the end of the week. If it does what all you pimps say it does then i think it might be the best $30 i have ever spent on a car :headspin:
Prior to installing it I pulled it apart again, I found the ball bearing is indeed NOT stainless steel, as I blew through it prior it had begun rusting the ball bearing. :rolleyes:
I cleaned it up and threw it in anyhow, appears to work well HOWEVER I am unable to wind any boost in as the cars been tuned with 12:1 afr's.
So more boost will = lean.
The stock rb20det turbo is crap anyhow, I might throw a cheapo VG30DET turbo on it until I get the money for the new turbo.
Prior to installing it I pulled it apart again, I found the ball bearing is indeed NOT stainless steel, as I blew through it prior it had begun rusting the ball bearing. :(
so can we get a stainless steel ball bearing from somewhere to replace it with?
can this be used on the r32? i cant see down to my turbo (theres a cover there) and havent really seen any other turbo cars..
i read that Jaycar IEBC thread and seen how you need a solenoid inline to the waste gate, im assuming this would go where the soenloid would go?
cheers, shaun.
cheers, shaun.
This is perfect for an R32.
    • Not alot of room in the front or mid pipe to play with Helmholtz chambers, plus they are pretty hit and miss getting the length and volume right, and time is money when it comes to trial and error testing at a exhaust shop, it isn't like test fitting mufflers or resonators From previous experience with exhausts and trying to tone down the volume and eliminate some drone, a resonator in the mid pipe typically make it much better,  and even possibly stop Jackie complaining about it, me, I really don't notice it that much, but, I am pretty deaf 馃ぃ
    • I know it's an entirely different engine, but I noticed practically 0 difference removing or adding 2x 3in (5inch body) 400cell cats (one in each bank) with regards to sound. So changing the cat to change drone I suspect will have very very, very, very, very, very very minimal impact.
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30掳bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • www.rollracing.com.au tickets aren鈥檛 live yet
