  • Replies 1.8k
Posted Images
HI froggy,
This is mark the maker and seller of the controller in question. I have them on ebay for $42 but I am continuing to offer the item to skyliners at $28 which includes express delivered.
They can be paid for by money order, direct bank deposit or by Paypal which is easiest.
Orders can be placed by simply emailing me at turbotech@aanet.com.au
and providing your name and address and I will in turn supply payment details. Too easy!
Cheers everyone,
Mark
HI froggy,
Cheers everyone,
Mark
Hey mark will send you an email as im very interested in buyimg one of these for my 32. Is this better than have an electronic boost system???
Depends on what EBC you use and how well its tuned. Most EBC's really need to be tuned properly to work well. The main advantage of an EBC is adjustable accurate boost control.
I had an avcr that wasnt working too well (wasnt tuned either though) and just bought one of these for testing, it does indeed work a treat. I run 1.3bar and it builds boost nice and quick and holds it well too.
Its a no name brand (as far as i know as it has no markings on it) it came with the car when i imported it. Opened up the glove box and there were 3 controllers in there. One is the boost and the other is the turbo timer (which i dont use) and i dont know what the other one is for???
Just thought i would try one of these valves and see how it goes???
ok I just installed mine. made a cut between my T piece (with looks more like a Y piece on the GTT) and what I thought was the wastegate actuator (cylindrical gold thingy) as per the instructions.
I must have done something wrong (wish somebody would post a pic) because I am getting boost to the top of the stock guage 1000mmHG when the allen bolt is fully screwed or fully unscrewed doesn't make a dif....
FFS! Help please... (I don't have a didge cam to take a pic either)
The connection from the boost control to the wastegate is not the best. I put the clamp from the charcoal cannister on it. Could this be leaking air and causing this?
HI this mark, the maker of the controller.
Ensure your have the barb that comes from teh controller at a right angle is the one that goes to the wastegate, the other barb goes to teh turbo.
Also, if you ahve been screwing th ebolt right in you may possibly have over tighten and jammed the spring. Remove the bolt and make sur the spring is freely sitting in the controller shaft (beb sure to put the ball back where it belongs)
Cheers,
Mark
From what I can see it looks fine. But just by looking at the bolt. It looks like you have it tightened up for MAX boost. I sent it to you on low boost which should be just slightly above what you were running. They are a very fine adjustment requiring just a 1/4 turn to make a difference of maybe a pound or so. It seems to me you have overtigtened the bolt and caused it to jam on full. Remove the bolt (while being careful that the spring and ball dont fall out) adn make sure the spring is not jammed down th ebottom. If so poke it out and drop the ball in down the bottom and drop the spring in on top. Once you replace the bolt as soon as it starts to touch the spring it is controller boost. Only slight adjustments are needed.
Cheers
Mark
ok mark after another test drive i wound out the bolt as much as possible. Still overboosting. Cause = end of spring stuck in thread. Pulled out spring and ball, put back in ball then spring.
Another test run. Still overboosting. This time spring not stuck but ball bearing lodged in the inside of the right angle part that connects to the actuator... this supposed to happen? Is the ball bearing supposed to be able to travel up that high?
HI you got me stuffed why your having grief LOL
The ball goes not in the right angle barb but the other one (the one that goes to turbo. Then put in bolt so there is atleast SOME pressure on the spring, the ball then can not possibly move up that far.
WHen re assembling the controller, be sure to not have it sideway or upside down otherwise its too hard tell if the ball went where it should..
Will resume testing tommorrow and post results. Have reinstalled made sure ball is in right place, spring is free and bolt screwed in enough to just start putting tension on spring.
Guess it must be in the right place otherwise I wouldn't be getting 1000mmHG boost equal to 18.8 psi I think. If tommorrow doesn't work out I'll have to take it out completely cos my turbo will die pretty quick at that psi even on very brief bursts.
Not sure did u check the pix on the previous page?
The fact that I am getting excessive boost tells me that I must have otherwise the solenoid would still be controlling the boost and not being intercepted?
Perhaps my unit is faulty according to Mark my install is ok going by pix...
Oh and is 1000mmHG = almost 19psi?
something is going wrong there. Its going to be related to the solanoid. You should prob bypass the solanoid and supply the boost controller with pressure from the compressor side of the turbo
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
