  • Replies 1.8k
Posted Images
VAPE you are a legend man!
finally someone put up a detailled view of it :ermm: ...
so it works fine and holds boost constant?
Cheers mate,
-JD
PS:
Your hose looks like its not fully secure.. actually it looks like its not even under the metal tie...
Edited by JD-33
finally someone put up a detailled view of it :yes: ...
Cheers mate,
-JD
PS:
Thanks JD.
Holy crap, i didnt realise that hose was not secured haha. maybe that is why my hicas light is on lol.
I got so confused about eveyone's directions on that controller, even the picture that was sent with the unit in the mail didnt make sense to me. People seems to put it in different ways. So I tried the manual version, and nothing happened, less boost and nothing when i turned the screw. then did it another way and it was overboosting like mad, so i had to unscrew coz i crapped myself thinking it would break somehting lol.
Anyway, thanks for pointing that out!
Vape
Thanks JD.
Vape
That "unsecured hose" is just a protective sleeve for your power steering line. What you have is normal and is nothing to worry about.
if any one can help my freind want's to know if you need two of these to run a 300zxtt.
If so how will it be needed to be tee'd.
the reason i ask is because he is so impressed with my jrdsports mbc they have a special of bulk buy and he want's to get some boost running through his mildly worked 300
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...AMESE%3AIT&rd=1
hey guys can anyone help me out? bought one of these, installed it on my 33, if i run anymore than 8psi boost it splutter, misses and carrys on between 4000rmp n 6000 rpm. i got some free dyno time (only kw reading, couldnt ajust ecu) the other day and had a play n the best rwkw figure i could get was only running 7.8psi boost! do i need to get on a dyno that can adjust my computer (timing, air fuel? also why do u thionk my car can only run low boost wen i hear of other people on here being able to run 10-11-12psi on the same car and not have any worries!
thanks 4 the help!
cheers
brett
Mark,
Transaction made via internet banking. Reference number quoted...
Cheers....
Did he reply back to you, i have been trying to get a response from him since last week, through here and through eBay. I would like to purchase it through here but i do need one soon.
I dont care i would order one through ebay if i really had to but if he cant reply to my messages, how is he gonna send the item if i hit "Buy It Now".
I would like a reply just for acknowledgement at least.
thanks 4 the help!
cheers
brett
try gapping you plugs to .7 or .6 and see if the miss disappears.
I suspect the miss is coil pack related from the symptoms you have described.
Hey guys just put this on my wrx with 181@ wheels on 16 psi, my old controller shit itself couldnt create no more boost. put this on and it totaly kicked its ass, hits 17psi by 3200 in 4th gear and holds it perfect there. im so glad i got this instead of something else... Took me about 1 minute to put it on and about 30 secs to adjust and i was soo happy with this product best 42 dollars i ever spent.
just got mine ine the mail! cheers buddy ill shove it in the weekend and see how it goes. took aa bit over a week to arrive but it says next day delivery lol. Dont really care as long as it gets here looks pretty good. thanks a lot to vape looks easier now
man just installed it, couldnt wait :) warmed up the car then stopped shoved it in on the side of a 70 road then checked what boost...it was a little bit "infinite" for my liking i had wound it out as far as possible and was expecting less than stock. turns out i used the wrong hose and after i figured it out (no net on the roads edge) it pulled to the mark between +7 and 0 on my stock r33 boost gauge.. in 2nd at like 2000rpm! kicks in hard used to sorta build over a second now its just bang. im not one to go over 3-4k rpm so im very happy with the result.
on r33 gtst, it is the two LARGEST DIAMETER hoses that are connected to the controller, everything else you can block or remove. Stock solenoid is taken out of the loop by removing the t piece and its small hose and plugging the other hose with a screw or similar. use the existing clips to hold the hoses to the controller and shazam u pull like a v8. a big v8.
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
