  • Replies 1.8k
Posted Images
Haha i just couldn't wait! I received mine today and just put it on 15min ago and took the Turbotech for a test and all i can say is HOLY CRAP! Did anyone say traction? :P It hit 12psi almost instantaneously!! it was all fun till the fuel cut defender came in :( so wound it back 3/4 turn and tightened the nut and went for another wrap... 9psi solid! No Spike! No Loss! All the way to redline! My car was boosting to 9psi before and i wouldn’t want it to boost any higher cause only stock cooler and stock ecu... Full boost came on at no more then 2400RPM... It took me like 2min to fit it into my R33 GTSt but getting the hoses off that T-piece was a nightmare! Just a bit of advice, spray some WD40 and twist using pliers and they will slip off... Great product Mark! Another happy customer! A+++
Regards,
Sarkis
i got mine today too... (well yesterday) i orderd on the 15th LOL. but all good i sent a email to mark and got it pretty much next day think it got lost in post?.
put it in the gtr and fark. hahah legs shaking is all i can say. hasnt happened since the first time i drove my r33 gtst wen i was a newb. hahhaha.
i even had the boost restrictor still lol
reading some of the responses, i hope no one has been dialling up huge boost settings just "cause they can" with this boost controller (like any boost controller). everyone of course should only be setting it to an amount theyre pretty sure the engine will take without issues, otherwise this $35 investment might end up costing you much more than that if your not careful.
if someone in brisbane can order me one I'll give them a $20 tip. Reason is because I dont have debt online banking or credit card :worship:
I need one and been asking a few friends if they could but they dont want me having a faster car. Sort of sucks as my fmic coming this week and my fuel pump is sitting here all lonely :D
Wow. 45 pages worth of posts about a simple mechanical boost controller :worship:
I got one of these yesterday off a friend (who had one spare at his workshop), after the HKS EVC II piece of junk that came with my car finally decided it had had enough.
If anyone wants to use one of these valves on a GT-R, find out which hose from the factory solenoid goes to the inlet manifold (should be easy to blow in with the engine running), connect this to the fitting inline with the adjustment screw. The other hose goes to the wastegate actuators, and will be hard to blow into (as it has no vacuum behind it), connect that to the last fitting.
Hey guys, i read that a few of you removed the "restrictor" on their R33... can someone plz PM me or post a pic of where it is located in the engine bay???
Cheers,
Sarkis
There isn't really a restrictor on the SII - it's the T-piece pipe that you remove from the hose going to the actuator that splits off to the dual solenoid.
Remove this T-piece, plug it in and see how you go.. I wasn't able to find an actual restrictor - others might have different suggestions..
ya i found a restrictor in the hose that connects to the intake pipe...
its a little gold thing inside the pipe... you can feel it inside the hose
its the black rubber pipe that connects to the T piece and to the intake pipe...
if anyone can upload a pic of your engine bay i can circle it for ya..
Thanks for your help guys, I have done about 75kms worth of driving today with the Turbotech and I have noticed a MASSIVE improvement in acceleration in 2nd and 3rd :ban: overtaking is so much more fun now lol I have it set to 9psi and its running beautifully... I think I’m might leave that restrictor in cause its not causing any issues as I have totally removed the standard solenoid from the equation... I seriously feel i have gained at least 10 - 15rwkw... it feels like the same increase in power since my full exhaust which gave me 20rwkw.. No complaints!
Anyone have any dyno comparisons from stock solenoid and with the Turbotech?
Regards,
Sarkis
I have had my turbotech boost controller in my car now for about a month with perfect operation.
But just recently i have been experiencing boost spike.
It used to boost up to 10psi and hold it rock solid. But now it shoots up to 12psi or so and then settles down to 10psi.
Do you think the spring is binding up or maybee moisture may be affecting the spring?
would spraying WD40 be a good idea or will it stuff it?
cheers
hey um basically i am interested in purchasing 1 of these, but what should i get to determine how much boost im cranking..
I dont want to spend $80 just to get a lcd screen unit which tells me my current boost, just so i can adjust the boost on the controller. I assume the stock boost controller isnt good for this because it only cranks to 7 psi and ive heard that the majority of stockish 32 gts-t owners are running theirs at about 12 PSI.. 12 PSI is about right yeh?
Is there some kind of tool i can hook onto some where that will tell me how much boost im running to help me adjust it???
Thanks
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
