Hi guys,
Glad you all like it.
Special for skyliners remians at $28 expresss delivered in AUS.
Just email me at [email protected] with your oder adn address, I will then send you my details and supply a ref number.
Cheers all,
You lot make me want to trade in my cordia for a skyline...lol
so why don't you??
  • Replies 1.8k
Posted Images
Hi Simark,
Just a quick question...
Can you use this to replace the skylines boost control solenoid and use it as a bleed valve instead?
Have you done any testing with this setup?
It seems possible.
I have just bought one of these on ebay (didn't know about the $28 skyline special. D'oh!)
When it comes, I was going to do some experiments and use it instead of the bleed solenoid, starting with the one way valve fully closed and then losening it off to bleed air.
Any quarms?
Thanks
Chris
Hi Chris,
To be honest I have limited knowledge of skylines and how they incorporate their solenoids. I believe the knowledge you require lies right here in this forum full of clever blokes. Just today a member who purchased a controller bypassed the soleniod I believe. Perhaps you could check back a page or so and read of his setup..
Cheers,
Mark
Yeah, I've rethought my experiments -
Don't want to break anything...
When I first saw this contraption, I thought that that was how it worked...
ie, remove the solenoid and plug it into when it used to sit, and bleed air.
Now I see that you plug it in where the solenoid t piece is.
Cool, Thanks anyway...
and its not a bleed valve.. it doesn't bleed any air...
it basically provides resistance to the air to stop it getting to the wastegate
so you start with no resistance (ie bolt fully out)then wind in as you increase boost.
starting with screw fully in will start with maximun boost and you will lose turbo very quickly..
Warren.
Warren.
Yeah, This is how I'm gunna set it up.
As for the bleed bit - I think you misunderstood me.
Maybe another way to say it is, this device was intended to be hooked up in series.
If you hooked it up in parallel, Theoretically you could use it as a bleed valve. So instead or restricting air to the actuator by tightening it, It would be bleeding air out by loosening it. Afterall, thats what the solendoid does. It's all in how and where you hook it up. (lost anyone, he he)
Anyway, It doesn't matter. I'm not going to risk blowing my engine for some experimentation. So I will be hooking it up in series - the way everyone else hooked it up. Can't wait to get it - I'm only running 6.5 pounds of boost ATM...
Yeehar!
Hooking it up in parallel like normal bleed valves would make this BC's features and design pretty useless wouldn't it?
Well like you, I'll just be hooking it up in series like everyone else and like the Jaycar EBC to get quicker boost and reduce wastegate creep (whatever that is ahhaha).
Andy
Hi guys,
Just reminding all who are receiving this controller shortly:
The controller comes pre-set at low boost, whcih which normally be slightly above whatever you are running now. I fully recommend NOT winding in the adjuster until after you have installed and tested on the road.
After this, only FINE adjustments are needed to get significant increases in boost.
Cheers
Mark
"Wastegate creep is when the wastegate is starting to open even tho your car is nowhere near full boost. As most wastegates work off springs they are set up to creep open as boost builds up. So your turbo is not spooling up as fast as it could since some of the exhust gas is being directed through the wastegate."
This is what I think is happening but would like to know more...
Excess boost is normally vented by the wastegate when boost pressure exceeds factory limts. This controller intercepts the boost and controls just how much pressure the wastegate sees (controlled by how much its screwed in or not). This used to be the solenoids job but now is the controllers???
Someone enlighten us! EDIT: Thanks Warren.
lol the question was how does this device eliminate wastegate creep. not what is wastegate creep.
well the spring is set to a tension so that the ball can only be opened by a certain amount of boost pressure. Before this pressure is reached, the ball and spring prevent ANY compressed air from getting to the wastegate thus prevent wastegate creep.
essentialy by the time the wastegate sees boost, you are already at your desired boost level ;)
Warren.
just wanting to know how this would work with a twin turbo car? would you just use a T piece to join both internal gates and then into this boost controller? and will it handle that fine do you think?
thanks
exactly. I have one of these on my GTR and it works magically. I had a avcr but was having problems tuning it so thought Id just give one of these a try seein how cheap they are anyway.
swapped the avcr solenoid for this (plumbing is all the same) and now it runs between 1.28 and 1.33bar peak on average (as the avcr is still monitering boost, just not controlling it) which is around 18.5psi-19.5psi roughly, which is close enough for me for a $30 boost controller that can get boost that accurate and hold it.
And as they say about the ball not letting any pressure through till its got the right level is true as boost hits really hard now, thank god for 4wd ;)
c what i'm having trouble understanding is:
springs F=kx pretty simple. Assumme k is constant ====> pretty good assumption.
now here's the thing:
The units of pressure (among others is) Pa, short for Pascal, 1 Pa=1N/m2. Basically Force per area. Now if an even pressure is exerted on an area u multiply the pressure by the area and u get a Force. By screwing the thing in and out u are changing x.
Now back to F=kx it is easily seen that F is directly proportional to x. hence pressure is proportional to x (since force=pressure*area, area is constant in this case). no matter if x has changed any force will force the ball bearing to move... ball bearing moves=> air gets to wastegate=>wastegate creep. Hence my confusion.
Unlike the jaycar IEBC where the wastegate only sees how much pressure u want it to c. is there some kind of seat pressure as with external gates?
Lets get rid of text book crap, and think along the lines of flow - how hydraulic diagrams are drawn.
Boost pressure ---> Screw Sol ---> Wastegate
So if screw sol wont let boost past till its 13psi, wastgate sees 0 psi.
Cheers
Matt
How effective are these in reducing wastegate creep?
I guess not as good as the Jaycar but if they are 80% as good that is pretty decent....
If I'm making full boost by say 3000rpm in 2nd gear (lightly moded R33) could this reduce it to say 2600rpm??
That would be nice
That would be nice
how efective is up to the opinions of those that have tried it
responses so far? almost as good an an EBC
so, let's say it goes something like the following:
%effectiveness at removing wastegate creep:
bleed valve - 60%
this boost controller - 90%
EBC - 100%
worth $28? i think so...
but saying that, i have not installed mine yet and hope the above is how it goes!
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
