  • Replies 1.8k
Posted Images
just make the hole where cubes said.
Mine has the pin hole directly opposite the nipple that feeds the wastegate actuator, so smack in the middle.
here's a pic
lol...as you can tell, i'm quite keen to see if this fixes the lag :)
It may not be the contoller that is causing the "lag". Lag between gears is normally because of long intercooler pipes. When you change gears the air gets released from the system, and has to travel all the way along the intake system again. This cannot happen instantly, so you may feel some lag. This is one of the reasons why the V-mount intercooler systems are so popular in Japan.
I've got a blitz LM front mount...pipes are shorter than all the hybrid/trust/hks etc kits....
Lag caused by a boost controller not releasing the pressure between the boostcontroller and actuator cannot be mistaken.
As you grab the next gear boost comes on really really slowly and smoothly. It sucks. :no:
Yes front mount systems add some lag to the setup but i feel that it is more throttle response rather than on gear changes at WOT that it effects. A simple test is just remove the boost controller and put a tee piece back in or a line straight from the ic piping to the actuator and you will see that the boost response is much better on changes-basically instantanious - hence the controller is causing the wastegate to stay open too long...
I brought one recently and it doesn't have the little hole in it. I don't get that lag everyone is talking about, I don't have an FMIC though with long piping. It does seem to drop of boost significantly (3psi or more) at high RPM though, but I assume this is something else, not the Turbotech MBC.
Anyway I've ordered the Apexi Boost controlle for the Power FC so I will give that a go.
that's pretty normal... 2nd of feb was a friday, so the money wouldn't have hit the account until about 6th or 7th . Gotta make it then, and then send it out, so probably not enough time to receive by today. Don't worry you'll probably get it mid-late next week some time. He's just a one-man-band.
well all is well, its sweet as to drive boost hits hard much harder than factory settup.
but the only downfall is that it looses boost up top. i have it set at 14 pound atm. and when it drops off up in the high revs it goes to 11-12 pound... so not too bad it still pulls.
definatly an improvement!!!!
next thing i will buy is an EBC but untill then im happy with this
even tho i had to drill the hole my self... grrr....
yes, drill the hole.
cuz if you dont it keeps your wastegate open when you change gears and it lags like a mo-fo.
so you need to drill the hole to let teh extra pressure in the line between the actuator and the BC out.
my 1.1mm hole works just fine, so id say anything around that size would be good :D
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
