  • Replies 1.8k
Posted Images
I think its just dissapointing that for something that was once fine now you have to modify yourself, certainly not an 'improvement'. I wonder why he changed it in the first place-maybe he was tired of drilling the hole or the ones with holes in em stopped being available or something. I might drill into mine today. :(
Edited by R33silverS2
Ok just want ot make this clear to everyone or anyone suffering from very laggy gear changes whilst using the turbotech. If you don't have the hole - DRILL ONE!! Today I drilled a 1mm hole directly opp the feed to the wastegate as shown in the pic and it made a wolrd of difference with gear changes. Previously the car felt totally dead, flat, sloooow when selecting the next gear - now boost response is fast. As you can see i highly reccoment drilling the hole!! :)
did u find boost now drops off up top?
funny thing is i took the car out for a run just for comparison sake....and there was no lag.
wtf?
anyway, i've left it for now. only change i've made was my cat. maybe that had some effect.
wtf?
Hmm so far so good, havent noticed any drop off as yet, but i onyl just kinda gave it a lil burn round the block - weather is dam hot here aswell so i didn't want to ring it out too much :) knock knock
I'll post up if i notice boost is dropping off up top.
I'm runnin 10lbs creeps up to 11.5 or so in higher revs then drops back down to 9 - 10 cant remember exactly. i think it goes something like 9, 10, 11, 11.5, 10 or something. so generally its around 10. i could never get my car to hold one boost level really well every since i did the exhaust, i think possibly the wastegate is too restrictive or small for the increase in flow and dump size. sigh] boost is never as simple as it should be...
i had a chat to mark he assured me that they do not make much difference. the holes are for higher boost applications 18.5psi+ to bleed out extra pressure. so im in doubt what difference the hole does on lower boost. but more on topic these are great and marks customer service skills are impeccable.
FOR SALE - Turbotech
Hey Guys, im selling my Turbotech due to upgrading to an EBC. If it wasnt for my high flow turbo set up i would of stuck with this little beauty. I have had it for approx 6 - 8 months and has helo solid 10psi without a single spike.
$25 + Postage (located in Sydney)
PM me if interested
Cheers
Edited by QRI05E
PM me if interested
Cheers
Hi,
I'm in Christchurch New Zealand.. I'm after one of these controllers but no-one wants to post..
I'd be very keen to pay your $25 AUD + freight to NZ + a bonus if you were keen on sending to New Zealand.. I can transfer funds via paypal if you're keen..
Thanks,
Scott Roberts.
markimak... thats a crock... i got PROOF not word off of somone that it lags like a bitch with no hole. buy one and put it in and tell me if its laggy or not...
mind you put 12 pound thru it not 7... cuz your stocko wastegate opens at 7 and i doubt having that hold will make a shit of difference with the 7psi.
well im runnign 14 pound neways...
with NO hole = pathetic
WITH hole = fantastic (altho it drops off pressure up top but im not complaining)
Mines got no hole and it doesnt lag at all, in fact it's brilliant. Running 11.5psi.
i have tried and tried to find the lag again, and its not there anymore. lol
quickshift, no prob. granny shift, still no prob, besides the obvious revs dropping out of boost range of course.
must've been the cat i had on. coz i didint have the lag issue before or after it. so no hole and still happy.
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
