  • Replies 1.8k
Posted Images
are these the same as the jrd ones? on ebay???
and the difference between the two is?
i noticed the spring inside is shit and gets bent and stuck. it this causing my boost spike problems?
well i reckon that's a place to start, regarding the differences between the two controllers. orignal is good quality, your knock off item is shit.
don't go bagging out the original when you've bought a piece of shit knock-off.
pretty damn simple if you ask me
Just got mine today and have a few questions.
-How do you know what the PSI is set at when adjusting the screw
-Heard mention of some having the hole filled/never had a hole
-How slight are the adjustments to the screw to raise the boost setting
-Is 10 PSI is a safe level for a stock R33
-Probably a stupid question but i dont know much about boost altering. When changing the boost level, is this altering the:
1) High Boost that comes on at 4500rpm
2) Low Boost that comes on at 3000rpm
3) Selected boost level at all times
4) None of the above, moron
Cheers for any help
you'll need a boost guage, or trust the factory one if you dare
it removes the two-stage boost, so it's the level you set all the time
you won't know what psi until you start booting the car and see what your guage is
10psi should be fine for a stock 33
don't worry if yours doesn't have the hole, it'll be fine
small turns of the screw = big difference in PSI, just be very small in your adjustments.
all the way out is less boost yes ppl's??
I just put mine in and it isnt too bad. Only drama is that it bounces to 12/13psi (as it set at the moment), then as it climbs thru the rev range, it does taper away down to 9/10psi.
Anyone else encountered a drop of that much? I had read that at the most around 1 psi drop is usual.
And whats the point of the hole in the actual device?
ANYWAY, it works awesome as it is. Has totally transformed the car (its auto), it has so much more oomph cause it comes on soo much quicker. Awesome little device
I have a JRD one from off ebay. Same kind of thing as the turbotech one and mine does the same thing as you described. It boosts to 12psi initially then instantly drops back to 11 but from there it gradually tapers off down to 9psi.
Reliability is good however, it never spikes, it spools up quickly and the boost is very predictable.
I'm really keen to get hold of a controller that can hold 11-12 psi right throughout the rev range - reckon I'd pick up 10-15kw just with that alone.
Most people I've spoken to say that the behaviour I described above is quite normal for this type of boost controller, so I'm wondering what other options I have, other than buying an expensive IEBC. There's always the jaycar kit which may be tempting. My brother's an electronics wiz so I'd get him to solder it up for me :3some:
Most people I've spoken to say that the behaviour I described above is quite normal for this type of boost controller, so I'm wondering what other options I have, other than buying an expensive IEBC. There's always the jaycar kit which may be tempting. My brother's an electronics wiz so I'd get him to solder it up for me :spank:
The next cheapest boost control method is to grab an adjustable actuator thats got the required boost level spring you wish from the local turbo shop. Down here ATS do them for $120.
They generally come in steps of 2psi. So 9psi, 12psi, 14psi, 17psi etc... Then use the adjustable arm to place a little more preload on it to fine tune the boost level.
From my fiddlings generally a bleeder will hold 2-3psi more than the actuator is rated at. Its a start. :3some:
Use both to help spool. :P
EDIT: OR.. You could always run an R32 RB20DET actuator? 11-12psi off the bat. :)
Use both to help spool. :spank:
EDIT: OR.. You could always run an R32 RB20DET actuator? 11-12psi off the bat. :P
Would this method build boost at the same speed as a stock setup though?
Not sure if its only at high boost but apparently the wastegate will sort of creep open with a stock setup, whereas with the turbotech controller or an IEBC the wastegate is kept closed (ie. it sees no pressure) right up until the desired boost is reached...
This is one reason I opted for the manual boost controller, its cheap, AND it (apparently) builds boost a bit quicker.
(actually, I'd love a SITC to reduce lag even further).
Am i correct in assuming that the hole in it helps it spool up quicker between gear changes. Cause mine being an auto, there is no throttle lift off as such that would require it to need such a function.
Would plugging the hole reduce the 5/6 pound drop that i am experiencing?
I read thru the first few pages of this thread (waaay to many to read for a lazy bastard like me) and noticed that the early ones didnt have a hole.
Also, would a faulty spring in the guts of it have this kind of impact?
It wouldn't the stock actuator has a weak spring so it starts lifting off much much earlier than the heavier rated actuator.
It still won't be as sharp as the ball/spring mbc but it will be pretty close. Which is why I suggested to use both, the mbc for boost response and the actuator so it holds boost >_<
installed mine today set it to 10psi but now when the car reaches about 5000rpm it starts to splutter only other mod i have is a cat back xzorst do i need a pod or maybe a dump pipe???
on the plus side it spools alot faster and less laggy
Most people I've spoken to say that the behaviour I described above is quite normal for this type of boost controller, so I'm wondering what other options I have, other than buying an expensive IEBC. There's always the jaycar kit which may be tempting. My brother's an electronics wiz so I'd get him to solder it up for me :nyaanyaa:
I also own the JRD unit, and have no issues, mine drops off from 15psi to 14psi but is rock steady from there, i also run a fuel cut defender and have a ces dump pipe, so i dont get any turbo back pressure, for the money of the JRD unit you cant go wrong and a EBC is not worth the money as they also have spiking issues.
As for the spring getting stuck its common with all ball and spring controllers, when winding just slow it down.
Well from my understanding, Having a hole can increase boost response between gear changes, but in doing so your creating a passage for the boost to escape and effectively not hold boost at higher rpm and possibly losing 1-5psi in the top end.
However, not having the hole it seems to hold the boost alot better. It will not lose boost at high rpm at all. So you set it at 12psi and it stays at 12psi throughout the whole rev range. Some have had problems with lag between changes with this setup, but I myself have not had a problem with this at all.
All in all, I would rather my bc holding the predetermined psi rather than losing 1-5psi later in the rpm.
After all isn't the point of a boost controller to control boost to which you set it at? Rather than not controlling it and losing psi?
If I recall correctly, I remember a member getting in contact simark87 about the differences in the 2 controllers and he said, the ones with the hole are for high boost applications which what he specified as 18+psi. And the ones without the hole for lower boost applications.
Mine doesn't have the hole and I'm very happy with the response of my boost even between gear changes. I'm even happier with the control of boost as it does not spike nor bleed off psi.
Cheers.
However, not having the hole it seems to hold the boost alot better. It will not lose boost at high rpm at all. Some have had problems with lag between changes with this setup, but I myself have not had a problem with this at all.
Well i got an auto, so i aint worried about lag between gear changes :P
Will plug it up and see what happens
got mine today, doesnt have the hole, i have no boost guage yet so im just playing around with it a little, if i boost it up to 7psi going by the factory guage, do you think that would b safe? i think my factory guage shows less boost than the car is actually running?
your stock gauge doesn't read psi, it reads mmhg. your stock boost at the moment is 7psi. If you bump it up to 7 on your stock gauge it'll be like 14psi.
edit: oh yeah, it won't be safe.
Edited by KeyMakeR33
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
