Can't keep the stock solenoid? Is this because its suppose to be running in series with the wastegate? How come bleedvalves can still use the stock solenoid though? Is it becuase they are running parallel?
So confusing lol. Thanks again haha.
Andy
  • Replies 1.8k
Posted Images
yeh,i got the other bleed valve off u CEFF1E,
i cant really see a difference in the two.
yeh ur 1 worked, i been runnin 14psi on my std turbo for over 1 week now:)
n i didnt connect anything back to the bov.
ok,the bleed valve i just took out,its not connected to the bov at all, in the instructions simark sent me,says i should connect it back to the bov, when i connected the first bleed valve to the bov, it wouldnt go up or down in boost,just made flutter noises
I've had this before. Only assuming, but - Sounds like the bleed valve is on the same pressure line as the BOV. The bleed valve will backflow and let presure in instead of bleeding when the throttle shuts and that means that there isn't a vacuum behind the BOV, so it wont open. Then the turbo surges.
Thats why I'm getting one of these...
My idle was higher, due to air backflowing through a bleed valve. Then I noticed that the BOV would not blow off when I increased boost.
So let me get this straight.
A bleed valve and this cool valve go in the same position.
A bleed valve lets air out thus reducing the amount of pressure the wastegate sees which in turns increases boost by delaying the opening of the wastegate until desired boost is hit.
This valve blocks the pressure completely from the wastegate thus increasing boost until the set pressure is met, the valve opens, and the wastegate opens as normal.
In other words, this cool valve will increase boost faster as rather than reducing pressure to the wastegate gradually, it blocks the pressure completely until the desired boost is hit when it then lets all pressure through opening the gate and holding the boost.
Comprende?
I'm having a few issues with boost control also and for ~$30 I'm willing to give this a go even if it doesnt work.
I noticed someone mention they received a blue one as opposed to the red ones pictured. What other colours are avilable? If possible I would prefer a black one.
Comprende?
i had a dog and his name was BINGO!
I guys
Thanks a heap for your interest in the turbotech boost controller.
I have now received orders for 30 and have already sent out 19 of them.
As all good things come to an end, the $28 price is unstainable with the cost and time involved.
I will of course continue to look after skyliners with a revised cost of $35 express delivered. Which is far less than I charge on ebay.
Pretty cheap for a F%^$ing great boost controller!!
Thanks gain
Mark
p.s keep those pics scoming its a blast to see them :headspin:
Hi guys,
please excuse me but I'm a little lost... I have a 33 gtst and have looked at my setup (stock solenoid) but don't fully understand where to put this.
Can someone post a pick of an R33 install... am I fitting it in place of the solenoid? ie, just remove the hoses from the solenoid and put them on the valve, if I remove the solenoid from the picture altogether, I'm left with three hoses. Which two do I use?
Sorry if someone has already made it clear, my eyes must be blurry
Received my boost controller today and have installed it. Um what can i say but OMFG are you serious. Got mine for $28 but now gone up to $35. Guys this is penuts. This is the best controller iv'e come across. I previously had a GFB bleed (rubbish) value and this unit simply replaces it in the same position as previously stated. I now have it set at 12psi and upon testing it, it did NOT spike at all and did NOT drop of at the top end where the GFB valve would spike and go from 15psi and drop of to 10psi. What a bargin for such a good product. Congratulations Mark and thankyou.
Get that patent happeneing.
Edit: Bummer, looks like you can't get patents if you have already sold the product. :P
http://www.abc.net.au/newinventors/txt/s1097642.htm
m sure you could work something out, maybe "CHANGE" wink, wink, nudge, nudge the design then patent that one instead??? :headspin:
I would like to add myself to the list of satisfied customers. I bought this valve about three weeks ago after reading the first post. This is definately the best $32.50 i have spent on my car, instant boost and no spiking!!!! :headspin:
I spent my weekend finetuning the boost and now i can fang with peace of mind
:wassup:
Yep i agree mark. you should patent these. if this is just one forum for one model of car and you have sold like 30 of them to us. Imagne if you distributed this on every car forum around the world.
Hehe guys the ball and spring design isn't something new, it's been around for a while. :rofl:
Still a great controller thought, mine is going fantastic, no spiking, constant boost that builds fast.
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
