Hay guys iam thinking of installing the Rsm and Avcr when i get my car and i wast thinking of putting the AVcr under where the cdplayer is i herd they come with a lil plastic thing that is made for that spot =)
and as for the Rsm i didnt really want to put it on dash and drill holes through it etc. =)
i was thinking of getting one of those Apiler things. that hold the guauges and put the rsm in that spot? dont know if it will work but its an idea huh +)
hehe or get one custom made?
any one know where poeple make this custom plastic stuff up???
in melbourne heeh
Tell me what ya think where did ya put yours =)
and post any pics if ya hve -)
I seen one car with an S-AFC + RSM + AVC-R all pasted under each other on the glove box lid.
Let's just say that all lit up, it looked like mission control.
Houston - we have a problem!
IMO they are a theft risk so I'm tinting my windows to hide that Apex'i shit.
T.
Yeah, anything that draws attention is bad, both for the perspective of it making it more likely for theft, and the fact that if a cop pulls you over all little gizmos on the dash are going to warrant further investigation if they're in the mood.
From what i've been reading any boost controller is pretty much illegal anyway? or at least makes the car unroadworthy.
I keep most of my electronics in my glove box...out of sight out of mind... however if i did have an RSM then i prob would put that somewhere in eye sight as you do want to be able to see that one easily for obvious reason when doing times and stuff....
Having it in the glove box works for me as it is there when i do wanna check stuff out and when i don't want drunk friends to play around with it close it up and then no touchies! still enough room in glovebox for normal stuff to fit in aswell
Originally posted by ex-static
Ive been pulled over heaps, cops didnt say anything about it, except how ca I afford a car like this and I must be a drug dealer... you know, the usual.
i'm with ex-static here....
I have my RSM on the dash... works a charm!
when I get the AFC it'll be in the single DIN underneath my stereo (as my deck is blue too)
and the AVC-R is going on the ashtray lid....*squeal*
blue boost gauge, blue dash lights... blue neons... mission control !!
I had the Apexi RSM mounted in the lid of the little box thing in the centre console. Problem was most of the time you couldn't read it whilst driving....too far from line of sight and reflection problems during day. Now it is on top of the steering column dead centre attached with hook&loop tape. It ocludes the revs from 0 to 2500 otherwise its fine .... any drunk mate who tried to reach it would be out of the car right then and there :P
hay ula32
mines on the ledge bit above the 3 centre console gauges. used double sided tape and the stand that came with it. not above the dash line, easy to read, no hassles (so far)....
what did you mean by the 3 centre console quages hehe?
does the double sided tape stick preety well? =)
here's a rough illustration...
http://members.optusnet.com.au/~ula32/DVC00004.JPG
the double sided tape that came with the avcr has got good traction.... very sticky :P
    • me too wasnt real happy and cost me a penny or 2 to replace
    • But there's the archetype for the name plate! Here's my view on that stupid TÜV ruleset. Buy a brand name aftermarket piece of equipment. In this case, the Mines front pipe we're talking about. Get it TÜV certified on the car. Damage the underside of it, say on a speed bump. Cut out the damaged section, replace with fresh metal. (For the sake of the argument only), continue doing that to the whole pipe until it is all gone, replaced with new metal. Is this grandfather's axe still the same front pipe? The design hasn't changed (much). The pipe walls are in the same places. The flanges are in the same places. It is functionally identical. How does this differ from a pipe that is ever so slightly different in fabrication (ie the number of welds in it, a few mm here and there in terms of where the pipes run, are joined, etc)? Anyone with 0.5% of a brain can see that there is absolutely no way that the performance (power, environmental aspects, noise, etc etc) of it can be any different than the genuine Mines pipe. Maybe even Mines made 2 versions of this design, with the same differences. How would anyone (say a TÜV inspector) ever be able to differentiate between them? And yet, they are so bloody anally retentive about this stuff. Mad. How upset would they be if you had the wrong spring washers on the flanges?
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
