Hay guys iam thinking of installing the Rsm and Avcr when i get my car and i wast thinking of putting the AVcr under where the cdplayer is i herd they come with a lil plastic thing that is made for that spot =)
and as for the Rsm i didnt really want to put it on dash and drill holes through it etc. =)
i was thinking of getting one of those Apiler things. that hold the guauges and put the rsm in that spot? dont know if it will work but its an idea huh +)
hehe or get one custom made?
any one know where poeple make this custom plastic stuff up???
in melbourne heeh
Tell me what ya think where did ya put yours =)
and post any pics if ya hve -)
I seen one car with an S-AFC + RSM + AVC-R all pasted under each other on the glove box lid.
Let's just say that all lit up, it looked like mission control.
Houston - we have a problem!
IMO they are a theft risk so I'm tinting my windows to hide that Apex'i shit.
T.
Yeah, anything that draws attention is bad, both for the perspective of it making it more likely for theft, and the fact that if a cop pulls you over all little gizmos on the dash are going to warrant further investigation if they're in the mood.
From what i've been reading any boost controller is pretty much illegal anyway? or at least makes the car unroadworthy.
I keep most of my electronics in my glove box...out of sight out of mind... however if i did have an RSM then i prob would put that somewhere in eye sight as you do want to be able to see that one easily for obvious reason when doing times and stuff....
Having it in the glove box works for me as it is there when i do wanna check stuff out and when i don't want drunk friends to play around with it close it up and then no touchies! still enough room in glovebox for normal stuff to fit in aswell
Originally posted by ex-static
Ive been pulled over heaps, cops didnt say anything about it, except how ca I afford a car like this and I must be a drug dealer... you know, the usual.
i'm with ex-static here....
I have my RSM on the dash... works a charm!
when I get the AFC it'll be in the single DIN underneath my stereo (as my deck is blue too)
and the AVC-R is going on the ashtray lid....*squeal*
blue boost gauge, blue dash lights... blue neons... mission control !!
I had the Apexi RSM mounted in the lid of the little box thing in the centre console. Problem was most of the time you couldn't read it whilst driving....too far from line of sight and reflection problems during day. Now it is on top of the steering column dead centre attached with hook&loop tape. It ocludes the revs from 0 to 2500 otherwise its fine .... any drunk mate who tried to reach it would be out of the car right then and there :P
hay ula32
mines on the ledge bit above the 3 centre console gauges. used double sided tape and the stand that came with it. not above the dash line, easy to read, no hassles (so far)....
what did you mean by the 3 centre console quages hehe?
does the double sided tape stick preety well? =)
here's a rough illustration...
http://members.optusnet.com.au/~ula32/DVC00004.JPG
the double sided tape that came with the avcr has got good traction.... very sticky :P
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
