y the negative,i tried this same thing my 32, turned the ignition off ,disconnected the positive(red) battery wire ,pumped the brake a few times n didnt feel any different,does it only work with the negative terminal being removed?
To answer the question.
The stock ECU is a learning ECU. It will adapt to certain conditions (such as fuel types, sensor performance etc etc). An example of how this works is my stock Air Flow meter started to die on me, but the stock ecu some how compensated for it. When I put the powerFC in the AFM had to be replaced.
When you reset the ECU your car will start the learning process again. Its worth doing on a car thats just been imported as the fuel is different in australia.
I would also leave the car with no battery attached for more than a few seconds.. count to 30 in french then re-connect the battery. :cheers:
would..
the ECU should have a series of decent sized capacitors to filter power into its memory.. Leave the battery off for 10 seconds, pump the brake pedal a few times and you should be right.
If you have been driving the car in australia for more than a few weeks then this whole exercise would probably be pointless as the car would have adjusted to aussie conditions.
There's a thread about this in one of the other sections...
You can also reset it by shorting 2 of the pins on the connector under the interior fuse box (drivers side)... Search for the thread... it's all there.
Turn key to acc, short, watch the check engine light flash a sequence... acc off, turn key, start engine.. ecu will be reset. No battery terminal crap and no loss of stereo settings etc...
**edit: this is for r33 s2's... don't know if it's the same for s1's...
  • 3 weeks later...
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
