Dear All,,
I would like your help in finding the correct Bearings for my engine, I had to take my crank to the machine shop and they said they must grind the crank which means I need to put in bigger Size Bearings. I was using NISMO Bearing and it was STD0 RRR40 but the workshop here don’t work with these numbers, so I need your help in :
1. Is it advisable to use the crank after all?
2. How will I know the correct size to use?
The work shop had measured the crank in came up with these figures :
Main Bearing size in STD is 54.98 and they have to grind the crank up to 54.48
Con Rod bearing size in STD is 47.98 and they have to grind the crank up to 47.73
Please help in finding the correct NISMO Bearings
Best Regards
Adel
https://www.sau.com.au/forums/topic/73433-rb26-engine-bearings-help/
Adel,
Going off the sizes that you have given it's more than likely that the crank has a bend in it. usually, if the crank needs to go .5mm undersize on the main journals it's because when it is set up in the machine running true on #1 and #7 main, #4 is running too far out to clean up at the first undersize. This happens quite often when a conrod bearing spins and the conrod journal gets very hot. It also means that you will end up with some conrod throws having extra stroke, if the mains have to go .5mm undersize, the extra stroke on a few cylinders could be up to almost .5mm which is bad for your engine.
Ask the machine shop if it is bent, or if the crank is already ground, ask them to check the stroke on each conrod throw. If either the crank is bent or the strokes are different on each conrod journal after grinding, throw the crank away and get another, it will save you troubles in the future and make a much nicer engine. you will be able to see if the crank had the bend ground out of it when you assemble it as the pistons will protrude more in the centre cylinders.
The other problem with going that far undersize is that you will be coming pretty close to grinding through the case hardening on the journals or even worse, on part of the journals.
Buying a new crank is the safest and I believe the best solution if you want your engine to last.
Not sure how much extra on top of machining a new crank would cost, but I think its worth it, or you might be back where you started.....another rebuild- its happened to so many of us
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
