I was down at the RTA transferring the registration for a car i had just bought when i started talking to the guy about the 15yr old car i'm importing (i was asking whether it is possible to drive it to the compliance workshop - which it is apparently).
But then he told me that after it gets the blue slip it may get knocked back by the RTA, meaning it has to go for a 3rd Tier inspection at an RTA station (because its more than 10yrs old).
He said that it might not happen, but that i should prepare for it so that its not a surprise
Has anyone had that happen to them? Is this common? I've heard they are extra strict there...
https://www.sau.com.au/forums/topic/73451-3rd-tier-inspection-by-the-rta-nsw/
they always pick imports for 3rd tier inspections.
they are 50/50 picks on any other car.
With the 15yr old imports they usually don't get inspected. Once you have Engineers certificate and blueslip, RTA just registers it.
With RAW complied vehicle getting registered in personal name, they always get inspected, but RAW vehicle getting registered in dealers name normally doesn't get inspected unless randomly selected.
They check numbers but also check for car in general. For example if car was too low they would probably knock it back.
Well, it has air suspension so height isnt so much of a worry (though even at 10cm height its hard getting up driveways!!!); I've had a look and to be honest there isnt that much 'defectable' stuff on it! (widebody/loud paint isnt illegal).
Got my fingers crossed though :P
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
