I've just brought a helmet from Revolution racegear and was wondering what was that sticker that you have to look out for??? I remember there was a few stickers on it, one was a British standard one or something??? It's at home so I'll post up later what stickers are on it. Helmet is for trackdays and stuff and CAMS doesn't specify anything on it's website, or maybe I'm just not looking in the right places.
Also I wanted my helmet painted. Where can I get this done? Preferably in Sydney.
Thanks!
https://www.sau.com.au/forums/topic/73455-race-helmets/
the latest Snell standard and Aus standards are the main one from memory. MFX does helmet painting. I'm sure there must be an FIA standard as well for the top level open wheeler stuff.
https://www.sau.com.au/forums/topic/73455-race-helmets/#findComment-1349218
Have a look in the back of the Auto Action (aka Auto Fiction) magazines for people who do helmet painting. Also, might pay to ask at Revolution as they should know people.
The brand of helmet you have will determine what stickers it has attached. My Arai (Japanese) doesn't have an Australian Standard sticker because it doesn't comply. It does, however have a SA2000 compliance & hence a cloth patch stiched into the lining.
If you have one, don't remove the Aus standard sticker!
There is also another applicable standard, but it doesn't spring to mind presently.
What make/model have you got?
https://www.sau.com.au/forums/topic/73455-race-helmets/#findComment-1349565
Track days are up to the company running it and normally anything will go.
CAMS allow:
AS1698
Snell SA90, M90, SA95, SA2000
SIS 88.24.11 (2)
DS 2124.1
SFS 3653
ONS/ONK
NF S 72 305
E22
BS 6658-85 Type A and A/FR
https://www.sau.com.au/forums/topic/73455-race-helmets/#findComment-1350375
ahh k then, wasnt planning on using it alot, ive seen fulfaced ones for about $130
if anyone see's cheaper let me know.
thanks
I grew up with a saying - "Buy a ten dollar helmet for a ten dollar head!" If they have a sticker they meet that standard... but other than that you get what you pay for... ie $130 poly carb.
TT
https://www.sau.com.au/forums/topic/73455-race-helmets/#findComment-1357749
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
