Phil Megroin Posted May 13, 2005 Share Posted May 13, 2005 Does anyone own one of these? Does anyone know how to use it properly? Whenever i turn mine on, and set it to .9 bar or even 1 bar boost, the turbo ALWAYS goes over the set amount. Whereas if it is off, the turbo happily spools up to .8bar and stays at .8bar. I dont know why if i set it .9bar it wont stay at .9bar.. instead it'll go up to .9bar, then over.9bar and then the needle on my boost guage goes a little crazy till it starts beeping at me. Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/ Share on other sites More sharing options...
caminperth Posted May 13, 2005 Share Posted May 13, 2005 I've got the manual to this at home (I think).. you need to calibrate the controller - it tells you how in the manual.. If I've got the file I'll post it.. Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1349460 Share on other sites More sharing options...
paulr33 Posted May 13, 2005 Share Posted May 13, 2005 ive got the unit and can remember the self reset have you had this controller working before? or is it one youve just installed? if youve just installed or brought it 2nd hand from someone try the self learn its in the manual Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1349530 Share on other sites More sharing options...
WetGTR Posted May 13, 2005 Share Posted May 13, 2005 I've got one of these in my car, work's perfectly. You need to activate the learn function so it know's how your car boost's and so forth. Usually this done on the dyno so you are able to load it up in 3rd gear, but can be done during driving. I have the manual, both installation and instructions. If you need them just let me know, I can just email them to you, they are in pdf format. Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1349848 Share on other sites More sharing options...
Phil Megroin Posted May 13, 2005 Author Share Posted May 13, 2005 Yeah I bought it with the car.. Thanks guys, i've found the instructions from the HKS website.. will be calibrating it this weekend, so hopefully it goes well.. just wanted to know why it kept doing what it did.. guess its not coz its properly calibrated. Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1350265 Share on other sites More sharing options...
chitnus Posted May 14, 2005 Share Posted May 14, 2005 Hey guys, Just tried to set my EBC.. how the hell do you do it? I've got the instructions - it says that the EBC should display a "3" when its ready to do the self learny thingy.. mine just stays on vacuum mode.. I just need to get it so that it stops spiking when i set it.. I dunno why it doesnt even seem to be working at all.. what are the different modes for? I've tried setting the EBC to .7bar, but my seems to just want to run .8bar. I dont get it.. does anyone have any instructions in laymans terms? Thanks. Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1351269 Share on other sites More sharing options...
zoom Posted May 14, 2005 Share Posted May 14, 2005 i have one also and it's working fine. the unit must be reset preoperly and do the self learn corretly first! well if you need help to setup and live in sydney western area, send me a pm Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1351287 Share on other sites More sharing options...
paulr33 Posted May 14, 2005 Share Posted May 14, 2005 what happens when you try the reset mode to go into self learning, does it come up with "3". if not what comes up?> Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1351385 Share on other sites More sharing options...
Phil Megroin Posted May 14, 2005 Author Share Posted May 14, 2005 Reset mode? Sorry i wasnt aware there was a reset mode.. how exactly do i get that? Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1351843 Share on other sites More sharing options...
WetGTR Posted May 15, 2005 Share Posted May 15, 2005 To reset the module you must do the following: With the iginition key in the on position and the power to the unit turned off, push and hold the "Mod" button. While holding the "Mod" button, push and hold the "Alt" button. Then while holding both "Mod" and the "Alt" buttons, push and hold the "Sbc" button. You should hear an audible beep. If you do not hear a beep, your unit may not have presets programmed in the unit. Hope this helps Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1351955 Share on other sites More sharing options...
PRO_32 Posted May 16, 2005 Share Posted May 16, 2005 Dude i wasnt aware the EVC III has an alt button. If so great if not. Try Turning the ignition on ( so that EVC has Power to it). On the back of the EVC there is a toggle switch that is used to select either internal or external wastegate. With ignition ON and EVC OFF press and hold SBC button in and flick the switch at the back from one to the other. ( make sure you put it back to internal or external gate) You should now have a 3 on the display. read manual from there. cheers Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1354940 Share on other sites More sharing options...
Phil Megroin Posted May 18, 2005 Author Share Posted May 18, 2005 Hey guys, Thanks for all your help.. I managed to reset the EBC, do the self learn thingy which set the boost at .76 bar When i use the adjustment mode (by Pressing Mode Only once) and set it to .80 bar it still boosts to .76 bar. I also tried boosting to .85 bar but once the needle on the guage goes up to .8ish the needle just goes haywire and pivots back anf forth really quickly.. At this point i can also hear the induction of the air from the turbo in bursts which coincide with the needle on the guage... Any suggestions? Also - just curious, what happens if you set the EBC to an internal (external) wastegate if your car actually has an external (internal) wastegate? Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1358965 Share on other sites More sharing options...
paulr33 Posted May 18, 2005 Share Posted May 18, 2005 the problem your talking about ive had before with the evc3. i found the cause in my case was loose wiring to the evc unit itself. i jiggled the wires that go into the unit and that fixed my problem Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1359156 Share on other sites More sharing options...
Phil Megroin Posted May 18, 2005 Author Share Posted May 18, 2005 Hi Paul, Nope i'm afraid that didnt seem to fix it.. its really getting frustrating.. Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1359476 Share on other sites More sharing options...
Midnight Racer Posted May 18, 2005 Share Posted May 18, 2005 Does anyone know how to change the boost setting for hks evc III ?? it work good but can not change the boost setting, how to do it?? thanks Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1360021 Share on other sites More sharing options...
zoom Posted May 18, 2005 Share Posted May 18, 2005 Hi Paul,Nope i'm afraid that didnt seem to fix it.. its really getting frustrating.. Phil, make sure your body valve (in the engine bay) is grounded to the chassi. Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1360080 Share on other sites More sharing options...
zoom Posted May 18, 2005 Share Posted May 18, 2005 Midnight Racer: here is a quick guide to set the boost! 1. press Mode to go to setting mode ie. boost setting 2. select either low or high boost setting by pressing SBC while press either low/high boost setting as required. 3. when in the low/high boost setting - dial in the boost required 4. then do the rest of the settings hope this will help!! Does anyone know how to change the boost setting for hks evc III ?? it work good but can not change the boost setting, how to do it?? thanks Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1360101 Share on other sites More sharing options...
Phil Megroin Posted May 23, 2005 Author Share Posted May 23, 2005 Phil,make sure your body valve (in the engine bay) is grounded to the chassi. Sorry i'm like a major n00b.. where abouts would i find that? How come you think that could be what the problem is? If the unit is not grounded.. doesnt that mean that the circuit isnt complete and hence the unit wouldnt work at all? Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1368458 Share on other sites More sharing options...
paulr33 Posted May 24, 2005 Share Posted May 24, 2005 the valve body is the black thing with hks logo on it with the 3 tubes. this is the solenoid. make sure its attached to the cars metal chassis somewhere, wether its bolted down or fastened down with a screw Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1369111 Share on other sites More sharing options...
Phil Megroin Posted June 16, 2005 Author Share Posted June 16, 2005 Problem fixed.. check the valve body.. was very tightly secured to chassis.. then jiggled around the wires coming from the valve body.. seemed to have fixed the problem. thanks for all ur help guys. Link to comment https://www.sau.com.au/forums/topic/73463-help-with-hks-evc-iii/#findComment-1412568 Share on other sites More sharing options...
