im having problems shifting to first gear when the car is in motion. eg: im going around 15km/h around a bend and i wanna gear down from second to first i have to use a bit off force to get it into first though if my car is idle or going under 5km/h theres no problem at all.
Any 1 got any ideas on what the problem is?
why would you want to put it in first anyways?
everytime im about to pull up to my driveway i have to slow down to the max to put it into first, y cant i put it into first while im a few metres from my driveway?
We sure do get some funny opinions on here. Like the [apparently] commonly held view that there is something technically wrong with changing back to 1st gear. No more than changing back to any lower gear! If you syncronise the speed of rotation of the gear driven by the engine, with that of the gear driven by the wheels - Viola!! or Presto!!! or whatever, then they will mesh easily and silently, and no damage done, and why not?
The syncromesh normally does this for you, but it becomes harder for the mechanism to syncronise speeds, the lower the gear, and the further apart are the revs of the 2 gears. Don't think my one finger could take writing a full description of how and why on this, however........
You actually can do this syncronising yourself by "double-declutching" sometimes known as 'doubling the clutch',which among other things will make your Syncros last virtually forever. It's a slower method of changing, but I habitually do it all the time, except when some nut 'has a go' and annoys me.
If anybody really wants a run-down of how to do it,I will,reluctantly write it up. Trouble is, it sounds much more complex than it is, albeit after a bit of practice.
With that in mind,when I went out to-day, I thought I'd see just what was possible [R32 GTSt] -- The first surprise I got was at the 1st Round a bout, when I found that I normally change back into 1st at between 15 and20k, because the exit of this round a bout, goes into one lane and there is mostly some Galah, who has gone around the outside, and is going to beat you to the one lane.. NOT!!!
I found that I do the change back to 1st so naturally, that I was not even aware of it.
So,,,,,,, I did some experiments and found it perfectly easy up to 30k. Got more difficult over 35k, in that you needed to be more precise with revs. As around 40k is about [i find] about the fastest USEFUL speed when going UP in 1st gear, there was'nt much point in trying anything else, but it would be possible, but useless, up to your rev limit.
Yeah, I looked and found it. My advice to anyone who does'nt already know all about it, to stay away from it. About 50% of it is wrong and the other 50% of it is not right!!! No, it's not quite that bad, but at least 50% of the opinion is wrong and the rest is only slightly more difficult to understand than the theory of relativity. They've all ignored the function of 'baulk rings', which is why Tracid Trax originally thought there was something the matter with his gearbox, because it was just plain not possible to force it in. Therefore,that's why those who say that double de-clutching is'nt necessary, or is a waste of time, are WRONG.
It allows you to go into a gear you want to go into, by the use of knowledge and skill, when the wonderful 'Do everything for you - you don't need to know, Syncromesh gearbox' fails. Before anybody trys to explain the double de-clutching method, or what syncromesh does would be well advised to first find out how a basic gearbox works.
As an apprentice our work truck was an international with no syncros so I had to learn pretty damm fast how to double clutch. they way I learnt was to listen to to revs (no taco)at certain speeds so if I had to change to that gear at that speed i'd rev to that sound and it would slip in with no crunch, up was allways easier than down.
hahah no synchros is a great way to learn. The other way is to drive the car without using the clutch for a while, you will soon know if you are getting it right or not :D
But Jax, don't you agree there is no real benefit to double declutching if your sychros are OK? We have had a lot of synchro trouble with our race cars but when they are OK good old heal toeing is all that is required
No, sorry, I don't agree. Unless the clutch is engaged when you rev the engine, then you don't bring the engine driven gears up to match the gears driven by the wheels. If you don't get those speeds right [with no,or worn syncros] or close, with good syncros, then the baulk rings will stop the gears meshing.
I know nothing about Eastern Creek, left Sydney before it existed, but very familiar with Oran Pk, Amaroo and most other Aust circuits, and agree that, as there are no, to my knowledge,1st gear corners anywhere [unless you lost it] then what you say is OK for circuit racing, BUT, I was addressing the original question of this thread. He needs to get it in 1st., and in an efficient way, and as I do on that round a bout the only way is by doubling the clutch. [There may have been a hillclimb or two around which may have had a 1st gear corner -- maybe there still is?]
By the way, some gearboxes won't come out of gear without using clutch - most will so long as throttle is floating or backed off. I had several GTR Toranas and none of them, M21 g/boxes, could be got out of gear without the clutch [not without so much force that you went straight thru neutral into another gear. Lost clutch several times - bloody nightmare]
By the way,again - like to see someone enter that round a bout with me and come out in front, without using 1st gear and without doubling clutch - Horses for courses.
    • No. GKTech arms have spherical bearings in them. No bushes. You will not need bushes for those arms. The sphericals are a bit of a maintenance nightmare. I have replaced all of mine several times in the 5 or so years I've had them, and I have the arms out regularly to clean and lube the balls. Worth the pain on an R32, because the standard arm design is trash. If you need the camber adjustment, there are other options (than the GKTech ones), although I would still lean towards and prefer the GKTech ones, even with the maintenance load of the sphericals. The caster adjustment is also highly valuable, allowing for setting the car up to drive straight. There are a million options for these, including the GKTech ones. I've had Tein rods on mine for 20 years and the balls are much less trouble in that location. Never given me a moment's pain. All positives, no negatives. I consider them compulsory.
    • Lol yeah I ordered the clips mentioned and as far as the amayama diagrams go i think thats all I'll need. Fogured id ask, sometimes people's first hand experience doesnt always match up to diagrams haha, i guess I'll wing it and worse comes to worse I'll just deal with it as I go
    • Thanks for all that information I appreciate it. To answer your questions: - Yep that's what I mean. These guys are professional painters to so I must be missing something. It's a bit hard to explain. - With the primer landing on clearcoat, I make sure that the surrounding clearcoat is scuffed to 240 grit as my epoxy primer says that I only need to sand the area to 240 grit. - Yeah so similar to the first question, assuming that the paint landed on the unscuffed clearcoat because I've seen that happen. - Yep I want to prep the surface in that order. Only reason because epoxy primer will protect it from rust and I need that atm with this crappy Sydney weather. I think I was worried about time, if I try to put the filler down but screw it up somehow and I don't have time to sand it off and reapply it then need to put primer later that it might start to rust again so I wanted to apply the primer as quick as possible to not deal with rust.  - I just deleted some answers, I just realised after watching a video and what you said about looking at the data sheet, that I need to read the data sheet on the specific filler I'm using. It's possible now that I put epoxy primer first was a waste of time and need to go to bare metal lol
    • I did. I went to a suspension guy and he told me because I don't have adjustable camber arms it's the reason why my car veers towards the left if I take my hands off the wheel but if I drive my other every day car and take my hands off the steering wheel it goes completely straight. I think it's common with Skyline's. In order to fix the problem, I likely need gktech camber arms then nismo bushes since I have poly bushes atm, then a wheel alignment after that. With my car if I take my hands off the steering wheel on a really bumpy road before stopping at a light I have to hold my steering wheel somewhat tight otherwise my car will legit just go completely in the other direction quite quickly and I'll slam into something lol instead of stopping straight. I Believe this YouTuber had the same issue and fixed it with gktech arms. At timestmap 6:05 he talks about how the car doesn't veer anymore after installing these arms.
    • hello! does anyone have a schematic that shows how to test the blower motor resistor for the vac system? i believe the part# is 27761-15U00. I think the resistor is toast, but would like to be able to test it somehow before i embark on the journey to find a new one. cheers! 27761-15U00
