Ok,
Entries for Round 5 of the WRX Club Track Days and SAU Vic Club championship are now available:
http://www.wrx.com.au/motorsport/forms/WRX...2Junesupreg.pdf
Sandown - SUNDAY June 12 (yep - right in the middle of the long weekend!)
$110.00 for Sprints
$100.00 for Driver Training
I have been advised that Sandown is always the most popular events on the WRX Calander and the events always sell out so I suggest interested parties get their entry forms in early.
Be aware also that there has been a change in Motorsports Director at the WRX Club so fax numbers and entry forms etc have changed a little.
:P and see you on the track.
https://www.sau.com.au/forums/topic/73467-wrx-club-rnd-5-sandown-june-12/
  • Replies 172
Meh - im happy for people to get pi55ed & BBQ'd at my place - its then a 10 min crawl to Sandown in the morning.
Or perhaps we could drink the Sunday night AFTER the track day seeing as we all have the Monday off it seems to make more sense.
Actually from what I gather they are just paranoid about Phillip Island as there are so many deaths at that track. I guss they figure at the other tracks the biggest risk is you smashing up your car but at PI bad accidents can happen cause of the speeds.
They also have no driver training at PI and are suggesting that maybe in the future they won't allow 1st timer track goers onto that track.
Ok, jut posted my entry in:)
Who else is in? And for a bit of laugh, who is going to bet me a case off beer that i cant get below a 1:25.99sec?:cheers:
Looking at how the car ran at Eastern she seems to be over her hissy fits so its time to wind up the boost with some new rubber :microwave
PS...does it look like there is going to be a lack of RWD modified again?
INASNT you pu55y!!!!!!
ROWDY32 you purse carrier!!!
Brisby - if you run a 1.26.xx I'll give you a slab.
If you run a 1.25.xx I'll give you a whole keg. I have one sitting in my office all ready.
So far Brisby I know the following are in:
Snowman
Roy
Scotsman (if clutch is ready)
Ant
Jag
wwwrxxx
ferni
I just read this thread!!!!! I thought it was for the 5th, so ignore what i wrote in the PM about the 5th.
Filling out entry form now :kick:
Also - pretty sure I could get the Ice Supra along as well.
He finally has the radiator in and the new stickies on so I'm pretty sure he's keen to give it another crack. That will give you your 3 RWD modified mate!
Sh1t! He was two seconds quicker then ill ever go last time:( So even if i get a high 1:25sec im still way off that thing:(
LOL..i need a 5 second improvement:(
oh...and anyone, in light of poor old Blind elks dramas at Winton, who wants to go halves in a 50L Drum of fuel? I shoudl be able to pick it up as im on holidays from next Friday
Brisby - the Ice Supra did a 1.25.8 as the best time last time. You sure you don't have your times confused? Either way - I think my keg is safe.
Also - Nige did a 1.09 flat at Wakefield on Friday as part of that Autosalon Car of the Year comp. Not bad given he only got 1 attempt due to a faulty alternator and he'd never been there before.
I will go halves on some 104 with you since u pinched half of mine at phillip island, but i just kissed the ass of an 1987 XJ40 Jag this morning on the way to work at the traffic lights. I put 2 big cracks on the front bar so dont know how it is at the moment to race with!!! :(
I was told he went a bit over 1 sec quicker then you/Emre/Chris:confused:
As for the Wakefield time, i odnt doubt the Supra is capable of those times, but i have a sneaking suspicion that it wasnt on the full circuit. A 1:08 from the Autostyle GTR and a 1:04 from Mr WRX...lol those times need authenticating. And if he only got one lap at the 1:09 then ill take my hat off to Nige, that is nothing short of brilliant....its akin to doing about a 1:35 at Winton in one go.
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
