Nope - he was 0.1s slower than me.
The 1.08 was a 1.08.95 apparently. And the 1.04 never happened. The car had gearbox problems and of coarse as people do (see Brisby) they said "If the car was running I reckon we could have got a 1.04". (Yeah right!) It was an un-backed up boast thats all. The GTR was fastest and the Supra was second - less than 0.1s behind.
It is the full track. Last year the best time posted in this comp was a 1.13. I told Nige he should be aiming for a 1.10 before he left.
  • Replies 172
Well like i said then, its an awesome job to do that time around the full circuit. If the GTR is quicker again with its T88 then again that is a brilliant job.
A WRX time of 1:04 isnt impossible, but knowing the sort of mods the car would have had, id say its very unlikley. Hats off to the Supra and the GTR, they are brilliant times considering the problems and the amount of track time they had. Even with perfect prep and plenty of practice they are still brilliant times.
Anyone have secondhand tyres(17s) that even diametter all round for sale? I now have proper rims for the GTR but ran out of dosh for the rubber :P .
Mr Brisby if i can get rubber in time i'll go harvy with ya on that magic drum ( if Inasnt car is not in that is ).
Love to run on Sandown since its near my joint.
I'll drag the new car down there and race you troy with the fuse pulled on a couple laps to see what the gtst could have done with bigger turbos. Will that put me in rwd modified as well as 4wd? It sould be a good chance to learn how to slide a gtr around because after almost crashing it at over 140k on a turn after owning the car for 5 minutes I don't really trust it on the tighter corners going fast. The back goes out like the gtst but the front wheels pull you into the corner so you have to correct to oversteer as soon as the back starts to loose traction which I guess just means I can't be as lazy at driving. See you guys there.
LOL...im so pumped about this day. Its shaping up to the be the first track day since getting to Melbourne where the car will be sorted without a problem with tyres, brakes and tune all sorted:)
Thing is i want to throw on a new turbo but fear this will eman another few wasted track days until i get IT sorted...decisions - decisions:)
Gareth - good to see you've learnt that driving a GTR quickly isn't as easy as some Hill Billy's like to think. We've seen your not afraid to punt a car hard and you already know Sandown so I'm real keen to see what you can do around there.
No need to pull the fuse either as Roy now has more than the required 3 RWD Mod entries to compete against.
Roy if your car doesent get towed off during atleast 1 session then it just wouldnt be right!!! :P
Yep - Nige is an SAU member. Member #053.
You also have Denham and Wayne anyways in RWD mod. So if Nige comes (btw - he has confirmed he is coming yesterday) that makes 4 cars in RWD mod at this stage to the best of my knowledge.
:P
Blah, blah, blah...ppl dont allow / listen to my excuses, so your time of ...that slow time...stands:)
And that goes for Sandown and Phillip Island:)
Me walks off talking about a waste of +300rwkws :)
You stop ragging on me and ill leave you alone:)
Dont have any cash for engine rebuilds at the moment so now 300kw runs :P
Is this ur first time at sandown?
Did a 1:36, a 1:32 then a 1:30.06 then it rained.:P
3 hot laps, LOL on the first hot lap i went off at turn 1 and flat spotted the front left tyre which left me with a horrible vibration all day and a tendency to continue to lock that tyre:(
At the end of the day i was doing 1:31s in the drying conditions:)
I put down 1.32 expected time on the entry form
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
