Hello peoples i need to do a bottom end rebuild on my motor broken piston and i am just after some advice, tride a search but didnt help much. This is what i am thinking about at the monement.
Block cleaned and honed.
Crank balanced.
RB26 rods.
Nissan mains.
Nissmo big ends.
Piston? ( i need help with).
Match the rods to the big ends and crank with the right clearences(anybody know of these clearences)
R33GTR oil pump with a jun adaptor(dose this sound right)
R33GTR water pump( do i need any adaptors with this)
And maby a metal head gasket(what are the standard ones good for)
This is a long term project, the rest of the car is fairly standard but i would like in the future to have a lot more power, so i need to do just the bottom end for now to get the car back on the road any advice would be good. :Oops:
https://www.sau.com.au/forums/topic/73491-rb25-rebuild/
I highly doubt a search gave nothing.
This have been covered with a hell of a lot of detail
basically, mine
Arias 87mm pistons
Prepped GTR rods
N1 oil/water pumps
Usual bottom end balancing and prepping
and thats it.
Had a topic on my rebuild to couple of weeks back
Mahle psiton
Mahle bearings
shot peened rb25rods
n the usual
plus bitta head work
https://www.sau.com.au/forums/topic/73491-rb25-rebuild/#findComment-1352137
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
