311 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 148
Hi people,
Go read SPEED magz issue 12...
there is a contest between 4 cars, GTT vs Supra vs RX7 vs S15....
SUPRA came LASTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT....
Sorry to see it.. lol
It might be fast in straight line but GTT will out run it on corners anydays...
BTW... for those who wants to know the resaults.. RX7 came first..
GTT is a good everyday car.. (i know i have one, use it everyday)
S15 ... is king of drift..
Supra... not much to say abt it... lol
r34 GT-T definetely... lighter, better looking, same amount of power standard :rofl: only downside is that it has a less amount of torque due to the supra having an extra 500cc n havin twin turboz instead of single
yep just took delivery of my GTT and have clocked close to 2000k's in 3 days! I can't stop driving it, its a brilliant machine with a great all round package, even in the tip-tronic. My old R33 doesn't hold a candle to the 34's stiffer ride, running gear, traction control etc. etc. etc. Not the quickest car in a straight line but in the corners it makes me smile ear to ear. Can't vouch for the RZ's performance although I dont think I'd swap this thing for anything but an R34 GTR :rofl:
Where can I find out more about issue 12 of SPEED magazine?? can anyone turn it into PDF? is it the latest issue?
Hi people,
Supra any day. A GTT isn't even in the same league imo.
Read some PRO's advice (SPEED) be4 u start to give stupid comments...
and what different league btw??
JDM vs JDM
FR vs FR
Tubro vs Turbo
both 14** kg vs 14** kg...
both 206kw stock????
WHAT different league???????????????? :headspin:
JDM vs JDM
FR vs FR
Tubro vs Turbo
im quite sure RZ's have 225kw stock
JDM vs JDM
FR vs FR
Tubro vs Turbo
Stupid comments? Let me clarify my post then.
By different league i meant that the Supra is a GTR competitor. Sure they're both JDM and FR platforms, but I wasn't saying that they are totally different cars.
The 343Nm of the GTT is quite a bit lower than the 451Nm of the Supra. That's almost 1/3 more torque. That's like comparing an RB20DET powered GTS-t and an RB26DETT powered R32 GTR.
BTW you really can't compare the power ratings as the Supra would have quite a bit more than 206kW.
EDIT: Changed the cars I was comparing
BTW I have read that Speed article, but it really is just an opinion piece. I can't see how they're "PRO's". Sure they've probably driven a lot of cars and are more qualified to judge the cars than me, but aren't they just fellow enthusiasts driving cars and then writing about them?
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
