WORK CR-Kai& MEISTER PRE ORDER end 28/05/05 + CURRENT STOCK
FIRST PREORDER
SAMPLES OF WORK CR RIMS
PRE-ORDER YOUR WORK RIMS FROM OFFICIAL AUSTRALIAN WORK DEALER.
GUARANTEED MADE IN JAPAN!
Closing date to pre-order : 28 mAY 05
To arrive : abt 1 - 1.5mths after pre-order has closed
Deposit needed: $400.00
Delivery (optional): $80.00 anywhere within Australia. If you think you can get cheaper delivery, please feel free to arrange your own delivery. I choose the courier company not based on the cheapest but the one that is reliable and will get ur rims to your door. As the saying goes "If you pay peanuts, you get monkeys!"
Color Available: Bronze, Gunmetal and White.
Prices as follows (inc.of GST and Tax) (each rims excluding tyres)
15 x 5.5JJ - $350.00
15 x 7.0JJ - $375.00
16 x 7.0JJ - $412.50
17 x 7.0JJ - $450.00
17 x 8.0JJ - $475.00
17 x 9.0JJ - $487.50
18 x 7.5JJ - $512.50
18 x 8.5JJ - $537.50
18 x 9.5JJ - $562.50
Price is per each wheel
Prices of rims in a set of 4 of similar sizes
15 x 5.5JJ - $1399
15 x 7.0JJ - $1499
16 x 7.0JJ - $1650
17 x 7.0JJ - $1799
17 x 8.0JJ - $1899
17 x 9.0JJ - $1950
18 x 7.5JJ - $2050
18 x 8.5JJ - $2150
18 x 9.5JJ - $2250
SOME OF THE COMMON QUESTIONS ASKED
Do you have any-more stock than this?
Ans: No, this is all i have
Can i order them?
Ans: yes you can, the pre-order is open for this purpose
I can get them cheaper somewhere else? Can you match it?
Ans: All works wheels are covered with warranty and it is the genuine Japan made wheels, i have seens copies of works wheel with exact packing and everything while in Thailand and Indonesia.
As an official dealer you can be assured that you are buying genuine product. All my item is inclusive of TAX and GST, and as you can from reputation, i deliver as promised.
What are the weight of the rims?
A ROUGH GUIDE ON THE WEIGHT
Size Offset Bolt Pattern Weight*
15x7.0 44 4-100 15 lbs (6.8kg)
16x7.0 44 4-100 17 lbs (7.7kg)
17x7.0 42, 47 4-100; 5-100; 5-114.3 19 lbs (8.6kg)
17x8.0 47 5-100; 5-114.3 20 lbs (9kg)
18x7.5 42 4-100; 5-100; 5-114.3 22 lbs (10kg)
18x8.5 30, 37 5-114.3 23 lbs (10.4kg)
18X9.5 30, 38 5-114.3 25 lbs (11.3kg)
____________________________________________________________________
*** IN STOCK AT THE MOMENT ***
To suit SKYLINE GTST - $2199
Work Wheels Emotion CR Kai Bronze 5x114.3 ET +30 18x8.5
Work Wheels Emotion CR Kai Bronze 5x114.3 ET +38 18x9.5
To suit S14, S15, SKYLINE GTST - $2199
Work Wheels Emotion CR Kai Bronze 5x114.3 ET +37 18x8.5
To suit all SKYLINE GTR32, GTR33, GTR34 - $2250
Work Wheels Emotion CR Kai Bronze 5x114.3 ET +20 18x9.5
To suit Accord Euro, S2000 or similar car
Work Wheels Emotion CR Kai Gunmetal 5X114.3 ET +42 18x7.5 - SOLD
To suit any 4x100 car
Work Wheels Emotion CR Kai Bronze 4x100 ET +42 17x7.0 - $1799
*** WORK MEISTER ***
Work Meister S1-2P
17 x 7.0JJ - $837.50
17 x 8.0JJ - $862.50
17 x 9.0JJ - $887.50
17 x 10.0JJ - $912.50
18 x 7.5JJ - $975.00
18 x 8.0JJ - $987.50
18 x 8.5JJ - $1,000.00
18 x 9.0JJ - $1,012.50
18 x 9.5JJ - $1,025.00
18 x 10.0JJ - $1,037.50
19 x 8.0JJ - $1,125.00
19 x 8.5JJ - $1,137.50
19 x 9.0JJ - $1,150.00
19 x 9.5JJ - $1,162.50
19 x 10.0JJ - $1,175.00
20 x 8.5JJ - $1,262.50
20 x 9.5JJ - $1,287.50
20 x 10.5JJ - $1,312.50
17 x 7.0JJ - $3350
17 x 8.0JJ - $3450
17 x 9.0JJ - $3550
17 x 10.0JJ - $3650
18 x 7.5JJ - $3900
18 x 8.0JJ - $3950
18 x 8.5JJ - $4000
18 x 9.0JJ - $4050
18 x 9.5JJ - $4100
18 x 10.0JJ - $4150
19 x 8.0JJ - $4500
19 x 8.5JJ - $4550
19 x 9.0JJ - $4600
19 x 9.5JJ - $4650
19 x 10.0JJ - $4700
20 x 8.5JJ - $5050
20 x 9.5JJ - $5150
20 x 10.5JJ - $5250
The price is for the following color: Black, white, Bronze and Silver dish with white spokes.
__________________________________________________ __________________
Work Wheels Emotion CR Kai Gunmetal 5X114.3 ET +42 18x7.5 - $2050
 Share
    • New dampening settings are much nicer or crappy roads, I've also noticed no difference when throwing the car around on smooth twisty roads In other news: Idle hands are the devils play things, or, more correctly, my typical while we're in there 5hit, and too much time on my hands with online shopping  Some new purchases for the 2.5 swap Fancy pants new 32mm triple flow radiator, because the old radiator is old and needs to come out for the 2.5 swap anyway Gates fancy pants water pump, because recommended with the new radiator  Plus a new silicone coolant hose kit,  because old hoses are old And a sump baffle thingo, because while I won't track the MX5, I'll probably track the MX5, maybe, probably......but, while we're in there anyway, as the FWD 2.5 sump needs to gets replaced with the RWD 2.0 sump, so, yeah I am loving driving the MX5 around everywhere, the poor old Bogan Cruise Ship hasn't really moved in months
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
