  • Replies 101
O.K.!
Order will go in this arv'!
People receiving much Skyline goodness are as follows:
Leech
SupaFly
4PKNUP
Frink(already paid)
SxyGTST
GM_GTR
MIVEC
trashed
OZR32GTR
and Geordie!
Coool: 10 DVD's on their way!
I'll post once I get 'em here!
Do i get a bonus for being first in with the order :( the gtr for the gts-t for a day but only after the new turbo's are on :)
O.K.!
Leech
SupaFly
4PKNUP
Frink(already paid)
SxyGTST
GM_GTR
MIVEC
trashed
OZR32GTR
and Geordie!
good dvd this one. i managed to find a xvid cos i'm cheap, but its good watching!
god do i want that asian dudes black 34. *drewl*
and that 300kmh run through the tokyo tunnel or whatever it is is awesome!!!
d
MMMmmm...Shin Inoue's R34 is a monster ,yes?!?
As for "Smoky" Nagata-san's run,well...those that haven't seen it(or heard it) NEED this DVD in their collection!
O.K.- They've arrived! All good :( -I guess this means I better get my butt out for our ritual gathering tomorrow night. Those I don't see,maybe next Tuesday night @ Jerra trivia night? Either way,$21 and you're all good to go! (and,no,I wont have change on me:bring the correct weight!) Fire up those DVD players,it's party time! :bananaman
O.K.- They've arrived! All good :D -I guess this means I better get my butt out for our ritual gathering tomorrow night. Those I don't see,maybe next Tuesday night @ Jerra trivia night? Either way,$21 and you're all good to go! (and,no,I wont have change on me:bring the correct weight!) Fire up those DVD players,it's party time! :bananaman
Woohooo... well now that I got my GTR back new clutch and all, I can probably meet ya's at the museum tomorrow night. What time do the crew(*edit*) get there?
Brad
9pm onwards it is then  :D
Oh BTW can you keep an eye out for me, I can only really remember Richard and Leigh(oh and Googs of course) from the Xmas cruise....
I'll be in a black R32 GTR.
Cheers,
Brad
I will see how i am going i might pop out but doubt it at this stage.
Cheers,
Brad
Hi Brad, I'll be out tommorrow but after 10.. will be good to see how your car's going... it's been ages :wavey:
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
