Fire up those DVD players,it's party time! :bananaman
Hehehe, if the delivery time on my incar dvd/tv is correct i might be firing up the dvd the very second i get it off you heheheeheh....driving gtr, while watching gtr? Would this be considered a bad influence on ones driving?
  • Replies 101
9pm onwards it is then  :P
Oh BTW can you keep an eye out for me, I can only really remember Richard and Leigh(oh and Googs of course) from the Xmas cruise....
I'll be in a black R32 GTR.
Cheers,
Brad
were all pretty friendly mate. we'll come up and introduce ourselves when you arrive.
Awwww man.... I probably won't be able to make it out tonight :-(
My brother has just got out of surgery after his 2nd knee re-co and I gotta head to his place.
If I make it out I'll give Jayce a buzz on his mobes....
Otherwise can I give you a buzz tomorrow Jayce and hook up to do a dodgy trade(cash for DVD:-p)?
Sorry and I was really looking forward to tonight..... next week maybe.
Brad
Righto:I'll be at the usual spot,but not for too long,'cause a/I'm stuffed,and I gotta work tomorrow and b/it's f***ing freezing,so no point hanging around longer than needed! Should be arriving in the mighty Liberty around 9.15-9.30ish...
thanks Jayce, the dvd's awesome, that top secret GTR was just scary and damn..1200 horses!!!, I also couldn't stop watching the laps at nurburgring with
dirk schoysman... wish I had the passenger seat though, makes me want to buy a gtr now, err hang on a minute... woohoo!! :headspin: :headspin: :headspin:
fantastic DVD!
i thought it started out a bit slow though. the english just dont get into it as good as the jap's do. they get all excited 'n' sh*t about the credits!
anyway, best $21 i've ever spent  :wassup:
thats what you said after you went to northside studios
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
