  • Replies 101
  leech_ said:
OZR32GTR picked up your dvd hope thats all good. I have sent you a pm with my details.
Thanks Leigh and Jayce!!!
Leigh,
I'll swing by on the way through to work today and pick it up..
Thanks again,
Brad
  leech_ said:
yea on the cover it said 44.95 so either he got them off the back of a truck or got a really good deal :P i am yet to watch the full thing but front the snippets i saw around at richards place when we all got together it should be awesome.
Actually,I got them 100% above board...I could of pocketted the extra dollars,but I thought I'd pass the savings on to my fellow SAU'ers
  4PKNUP said:
hey jayce you gonna be at the museum tomorrow night? coz i will swing passed and pick it up
I should get there;it depends on how far I get tuning a certain blinged-out Forester GT. If it all comes together,I'll be there at 9ish. Looking at the weather,I'd imagine no one in their right minds would hang around for long;I'll be in that same basket of not wanting to get frozen...although,with a new 'cooler and bigger turbo on the GT,it'd mean a bit more boost,would it not?!?
Nope;I'm out-maybe catch me at the go kart day on Sunday? If not,let me know hwere you are,and I'll find a way of getting to you...
  4PKNUP said:
hey jayce!!!!!!!!!! i em doing work experience at integra and the bling mobile is there so if you can drop me the dvd would be great plus i got to drive her onto the hoist today :) don't worry i was very careful ed was even giving me sh!t about it haha
No prob's-I didn't know you were there! See you in the morning;got photo's to take of the GT...
  4PKNUP said:
hey jayce!!!!!!!!!! i em doing work experience at integra and the bling mobile is there so if you can drop me the dvd would be great plus i got to drive her onto the hoist today :D don't worry i was very careful ed was even giving me sh!t about it haha
ahh i cant wait till i start my week there :)
Righto;the remaining two DVD's that were ordered by SAU ACT'ers originally are up for grabs as said members haven't pulled fingers out of butts...Well,only ONE is on offer;gun32gtr has been patiently waiting for someone to bail out,so his copy is covered(Kane;send me a PM and we'll organise it). As for the other copy...better hop to it!
  R31_silo2 said:
jayce i will give you 21 cash, and then i will burn others for 10 dollars if anyone else would like a copy??? otherwise would i be able to borrow yours for a night or two so i can burn it?? cheers gus
Gus,you l'il pirate...you're welcome to an original copy for $21;what you do after that is up to you! And, no;you can't burn copies from mine...Quick payment or someone else is the lucky recipient,OK?!?
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
