clayoth Posted May 14, 2005 Share Posted May 14, 2005 What does "v spec" imply on an R33 GTR? Thanks in advance. ...yes, I know this question is probably in the wrong area... Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/ Share on other sites More sharing options...
RedEmblem Posted May 14, 2005 Share Posted May 14, 2005 V Spec stands for Victory Spec. R33s badged with V-spec have slightly more torque - I don't know how they got it though. I think the R32s have an LSD system - which is the same as the racing fellows used. The R34s badged as V-spec have stiffer suspention. Btw are all R34s V-spec? Correct me if I'm wrong on any of that, guys. Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1351339 Share on other sites More sharing options...
ferni Posted May 14, 2005 Share Posted May 14, 2005 search the forum for 'vspec differences' and you'll get a huge load of info. Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1351388 Share on other sites More sharing options...
slyline Posted May 15, 2005 Share Posted May 15, 2005 Does V-Spec mean GTR Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1352416 Share on other sites More sharing options...
IOWNU Posted May 15, 2005 Share Posted May 15, 2005 Yup. Also available are V-SPEC II and M-SPEC (R34s only I think) Haven't got a clue about the differneces. Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1352434 Share on other sites More sharing options...
Dush Posted May 15, 2005 Share Posted May 15, 2005 Whats M-spec then? I've seen a R33 GTS-T wit M-spec on it? Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1352628 Share on other sites More sharing options...
Duncan Posted May 15, 2005 Share Posted May 15, 2005 M-Spec was a seperate spec level in the R32 GTSTs (different bodykit, not sure what else)? All R33 GTS25ts are M-Spec though. Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1352641 Share on other sites More sharing options...
HCR32 Posted May 15, 2005 Share Posted May 15, 2005 M-Spec was a seperate spec level in the R32 GTSTs (different bodykit, not sure what else)? All R33 GTS25ts are M-Spec though. yeh in the r32 range, mines a mspec, twin piston front calipers and sunroof aswell? not sure on the sun roof but mines got the above.. Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1352789 Share on other sites More sharing options...
daler32 Posted May 15, 2005 Share Posted May 15, 2005 mines r32 m spec got sunroof and better front brakes also Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1352798 Share on other sites More sharing options...
paulr33 Posted May 15, 2005 Share Posted May 15, 2005 http://imports.motortraders.net/imports/se...yline&period=79 lists all of the r33 skyline factory options Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1352840 Share on other sites More sharing options...
Grant Posted May 15, 2005 Share Posted May 15, 2005 We're getting off track a bit, but I've got an R32 gtst m-spec, no sunroof though, so obviously they aren't standard fitment. Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1352844 Share on other sites More sharing options...
fane Posted May 17, 2005 Share Posted May 17, 2005 you can get v-spec gtst, paul has one in perth, it has an active lsd system... i dont know any other differences... Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1356657 Share on other sites More sharing options...
paulr33 Posted May 17, 2005 Share Posted May 17, 2005 http://members.dodo.com.au/paul/documents.html 4th from the bottom "How to pick out a real Vspec from a fake one" Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1356663 Share on other sites More sharing options...
RedEmblem Posted May 17, 2005 Share Posted May 17, 2005 I didn't know of any V-Spec GTSTs, I thought pretty much all (if not all then all SII GTSTs) GTSTs had active LSD. Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1357326 Share on other sites More sharing options...
readyGO Posted May 18, 2005 Share Posted May 18, 2005 Is it realy a big difference with Vspec I or II compared to normal GTR r32? my importer is trying to convince me not to worry to much with vspec.......pls help Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1359767 Share on other sites More sharing options...
readyGO Posted May 18, 2005 Share Posted May 18, 2005 also, i know there are brembos in the vspecs... but other than that are there any differences? what is the Atessa system? can i change this.... help : Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1359774 Share on other sites More sharing options...
Duncan Posted May 18, 2005 Share Posted May 18, 2005 there are no practical differences between the vspec I, II and regular models. For the extra you would pay for a vspec you can buy the same or better brakes, they bolt straight on. The other key difference in vspec II is the standard rim size but of course everyone changes them anyway. Don't bother, buy the regular model and do the mods you want. All the key things are the same, engine, Atessa/4wd, abs, suspension etc etc etc Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1359846 Share on other sites More sharing options...
kudos.motorsports Posted May 18, 2005 Share Posted May 18, 2005 The V-Specs received the ATTESA E-TS PRO system rather than the standard ATTESA E-TS. This PRO system allows for driving and braking forces at all four wheels independently rather then just front and rear. Therefore making the V-Spec are more suited to track than standard GTRs. Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1359871 Share on other sites More sharing options...
Duncan Posted May 18, 2005 Share Posted May 18, 2005 The V-Specs received the ATTESA E-TS PRO system rather than the standard ATTESA E-TS. This PRO system allows for driving and braking forces at all four wheels independently rather then just front and rear. Therefore making the V-Spec are more suited to track than standard GTRs. not in the R32 I'm afraid Yes the 33 and 34s have different ATESSA systems, the vspec being faster and better calibrated Re the ABS "independant braking force at all wheels" the 32 has 3 channel ABS (front left, front right and rear) while the 33 and 34 have 4 channel ABS (each wheel independant) Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1359882 Share on other sites More sharing options...
kudos.motorsports Posted May 18, 2005 Share Posted May 18, 2005 I was only answering the man's question. "What does "v spec" imply on an R33 GTR?" Link to comment https://www.sau.com.au/forums/topic/73566-what-is-v-spec/#findComment-1359890 Share on other sites More sharing options...
