Hi.
My HKS EVC IV instructions say: Ports 1, 2 and 3 must face upwards with port number 4 facing down.
The person who installed it into my GTR in Japan put it down flat under the pods. All ports are at the same level.
Does anyone know why it MUST be vertical? Does anyone know of any side effects of having it flat?
While I'm asking, does anyone know what port 4 does?
Many thanks,
James
https://www.sau.com.au/forums/topic/73571-hks-evc-iv-question/
Hmmm ... What do you think would be the consequences of getting oil in it, and not being able to drain it out?
The setup doco I downloaded from the US HKS site only shows the left and centre ports on the top being connected to the external wastegate.
There is nothing in any of the diagrams in the Japanese manual that shows port 4 being connected. Do you think maybe I am supposed to take the cap off occasionally and clean out any collected oil?
Update: Ricky from mrcontrols.com says:
The 4th port is the air vent used to maintain steady reference pressure in the actuator. They tell you to point it downward to prevent possible water or contaminants from leaking into the control system. If you have the unit mounted in a location where it cannot get wet or extremely dusty, you should be fine.
It sounds reasonable, but some of the threads on oil bottles suggest there is likely to be oil vapour in the air. The air goes through the actuator. There is a good chance oil gets into the actuator too.
Any thoughts?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
