Kumho prepares to debut 'red smoke' drifting tire
May 6, 2005
Kumho Tire U.S.A. Inc. has developed a tire that produces red smoke for drifting competitions.
The tire, a special version of the Kumho ECSTA MX ultra-high performance street tire, is dubbed the ECSTA MX-C. It will make its public debut with Enjuku Racing at the Formula Drift event at Road Atlanta on May 6 and 7.
Enjuku tested the MX-C for the first time the week of April 18. "When we saw the red smoke boiling off the rear tires, we just stood there and stared in awe," says Enjuku lead driver and team captain Matt Vassallo. "I think people will be blown away when they see this."
The ECSTA MX-C was developed at the Kumho Technical Center in Akron, OH. "At a product meeting here late last summer, several people were talking about the sport of drifting," says Manager Guy Edington. "While watching a drifting video, someone opined that it would be cool if the tire smoke coming off the cars was colored."
From there the idea blossomed, and Jim Palombo, Kumho's senior product chemist, and Gary Bradnick, lead lab technologist, set about looking for a way to make colored smoke. They developed the right mix of chemicals and now have a patent pending for their colorful compound (they've also developed a compound that produces blue tire smoke). Following successful testing, Kumho produced a limited number of the tires.
"We don't intend to sell the ECSTA MX-C to the general public," says Rick Brennan, Kumho brand director. "We built them to demonstrate our forward thinking, technical capabilities and ability to respond quickly to the market." The MX-C was developed in about six months.
"With the car show market and drifting scene ever-expanding in the U.S., the constant effort to make your vehicle stand out in the crowd is the ultimate goal," says Vassallo.
:D:) :)
https://www.sau.com.au/forums/topic/73582-red-smoke-drift-tyre/
Just another way for the cops to know when you're baggin em up. They can just say they saw red.
Or maybe the cops could get one red and one blue so everytime they pull a skid (everytime someone looks like jaywalking) they could match the lights up top.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
