Hey guys
just some stock bits im trying to get rid of...
Stock R32 A/C Compressor - $50 SOLD
Stock R32 A/C Condensor - $50
Stock R32 P/S Pump (Hicas) - $50
Stock R32 Heatercore (I think, some thing. looks like an intercooler. lol. sits behind dash, something to do with aircon.) - $20 bucks!
Stock R32 Intercooler - $50
Stock R33 Auto Flywheel -$50
Stock R33 Series 2 TPS - $80
Momo Shifter, small scratches - $40 bucks Looks like THIS!!
Stock GTST Dump and Front pipe - $20! SOLD
Stock R32 Hicas Rear Steering Rack - $20!
Stock R32 Front and Rear SwayBars - $50
Stock R33 Blow off valve - $20 SOLD
AutoTechnica Leather/Aluminium Steering Wheel. 33cm, flat bottom. Looks like the one on the left SOLD
Open to offers on absolutely everything.
all needs to go.
Cheers :D
https://www.sau.com.au/forums/topic/73590-random-sale-stock-bits-and-pieces/
i'll take the stock r33 bov
$20 done
pm me to how i can get it, coz mine has been welded shut to make flutter, this hasnt been done to this one either has it?
i just want stock untouched r33 bov
cheers
-Ruffels
compressor works perfectly.
was in my car working a dream...
therefore i take it compressor sold to z3n2k and bov sold to ruffles.
quick and easy :) nice.
Will PM you both now...
Cheers
do you have the black 30mm plumback pipe from factory bov to inlet??
or the hose from 90degree aluminium pipe to plenum?? (throttle bypass hose)
prolly a random one but just asking :P
i do have the plumback return pipe, only the r33 one though (dont think there is much difference except for a vacuum nipple.
but not sure what the second thing is your asking about so i dont know. but there is a good chance i got it :)
sure you can come look at the knob...
they are noticable when looking at them but when the gear knob is in the car you dont really see them...
i was only using it as i tihnk it it is really nice to use.. i didnt have it to look good ;)
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
