Hey guys
just some stock bits im trying to get rid of...
Stock R32 A/C Compressor - $50 SOLD
Stock R32 A/C Condensor - $50
Stock R32 P/S Pump (Hicas) - $50
Stock R32 Heatercore (I think, some thing. looks like an intercooler. lol. sits behind dash, something to do with aircon.) - $20 bucks!
Stock R32 Intercooler - $50
Stock R33 Auto Flywheel -$50
Stock R33 Series 2 TPS - $80
Momo Shifter, small scratches - $40 bucks Looks like THIS!!
Stock GTST Dump and Front pipe - $20! SOLD
Stock R32 Hicas Rear Steering Rack - $20!
Stock R32 Front and Rear SwayBars - $50
Stock R33 Blow off valve - $20 SOLD
AutoTechnica Leather/Aluminium Steering Wheel. 33cm, flat bottom. Looks like the one on the left SOLD
Open to offers on absolutely everything.
all needs to go.
Cheers :D
https://www.sau.com.au/forums/topic/73590-random-sale-stock-bits-and-pieces/
i'll take the stock r33 bov
$20 done
pm me to how i can get it, coz mine has been welded shut to make flutter, this hasnt been done to this one either has it?
i just want stock untouched r33 bov
cheers
-Ruffels
compressor works perfectly.
was in my car working a dream...
therefore i take it compressor sold to z3n2k and bov sold to ruffles.
quick and easy :) nice.
Will PM you both now...
Cheers
do you have the black 30mm plumback pipe from factory bov to inlet??
or the hose from 90degree aluminium pipe to plenum?? (throttle bypass hose)
prolly a random one but just asking :P
i do have the plumback return pipe, only the r33 one though (dont think there is much difference except for a vacuum nipple.
but not sure what the second thing is your asking about so i dont know. but there is a good chance i got it :)
sure you can come look at the knob...
they are noticable when looking at them but when the gear knob is in the car you dont really see them...
i was only using it as i tihnk it it is really nice to use.. i didnt have it to look good ;)
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
