I got a new front strut brace which incorporates a brake master cylinder stopper into its design.
Just thought I would post some feedback on the effectiveness of it.
As soon as I drove the car I could notice the difference in pedal feel. Instead of feeling a spongy/soft, the pedal is nice and hard. Also prior to fitting this I would get a slight vibration while braking. This is gone. I'm don't believe it alters the effectiveness of the brakes, but IMO is worth it just for the pedal feel.
I hope this helps someone :D
ps I don't know the thread of the bolts used to attach it (first question I had when fitting). some bolts I had lying around fitted :)
https://www.sau.com.au/forums/topic/73591-brake-master-cylinder-stopper/
www.nismo.com.au have them for $99. they also sell a strut brace with built in master cylinder stopper (what i got) for $165.
Remember to mention that you are an SAU member to get your 5% discount :P
I went and got some new bolts (so they were pretty and matched). I took one of my other bolts along that fitted and matched it up to a thread tester which stated that the thread was (metric) 6 x 1.0 mm. The bolts I got were labelled as 6 x 40 mm (ie 40 mm long).
edit: 40mm is too long go about 25-30mm
OK people....speaking of the clutch master cylinder flexing....today the clutch hanger snapped the spot welds. The two bolts that poke through the firewall, if you look inside the car there is a bracket the clutch pedal hangs off with the studs for the master cylinder going through the wall... It popped the spot weld(s) on the left hand side of the bracket.
It now needs to be taken out and reinforced then put back in. It leaves me worried what will brake next when i put it back. Time to make the clutch stopper....
(ive got a OS twin plate clutch so its by no means a heavy pedal either:))
We have had the same thing happen to the R32GTST race car and it has an OS Giken twin plate in it as well:cheers:
unfortunatly no. As the bracket curves downward making cableties slip off as you push the pedal in.
I tried cableties, and using some small vice grips to clamp the bracket together. I was stuck at work in the carpark, and had to call a towtruck to get it home :D
don't cable ties fix this problem Gary :D
Yep, if you use enough of them and they are big enough. Plus you need to be able to lie upside down with your feet on the driver seat headrest and your head on the brake pedal for half an hour while you do it. All without throwing up. :wassup:
I tried cableties, and using some small vice grips to clamp the bracket together. I was stuck at work in the carpark, and had to call a towtruck to get it home ;)
You have to use one cable tie over the front to hold the others in place. It took me quite a while to work it out, but we were at BATHURST and I wasn't missing out on a run down Conrod. :D
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
